[postgis-users] Geocoding
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Fri Feb 2 13:05:54 PST 2007
The Tiger data is getting better.  At least here in North Carolina, the
Census Bureau is working with the local county governments to produce an
enhanced TIGER dataset .   7.6 meter accuracy for roads.  They want to be
done by 2008.
Related links below.
http://www.census.gov/geo/www/tiger/future/future_tl.html
http://www.census.gov/geo/mtep_obj2/mtr.html
http://72.14.209.104
/search?q=cache:RsQ3w_Wgn9EJ:wagic.wa.gov/Presentations03/Aug18/MB082103%2520WAGIC%2520MTEP%2520Update.ppt+census+TIGER+enhanced&hl=en&ct=clnk&cd=36&gl=us&client=firefox-a
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
I left my signature file in /dev/null
             "Rob Tester"
             <robtester at gmail.
             com>                                                       To
             Sent by:                  "'PostGIS Users Discussion'"
             postgis-users-bou         <postgis-users at postgis.refractions.
             nces at postgis.refr         net>
             actions.net                                                cc
        Subject
             02/02/2007 03:29          RE: [postgis-users] Geocoding
             PM
             Please respond to
               PostGIS Users
                Discussion
             stgis.refractions
                   .net>
I think that the task of geocoding is fairly easy and I have written a
geocode function that uses PostGIS. However, the problem is where to get
the data. In the U.S. you can use Tiger line data from the census, but it
is horrible inaccurate.  If you have resources you can purchase more
accurate data from other companies like Navteq, or manually correct the
census data.
Rob.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stone,
Matthew (DHS-HISP)
Sent: Friday, February 02, 2007 1:15 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Geocoding
Does/Will PostGis have a Geocoding routine built in such as ArcSDE has
locators and geocoding processing?  I am curious, as geocoding is the
building block of any GIS work I do and I have need of decent open-source
solutions that can process millions of records in a batch mode, or can be
implemented on the WEB as a “geocoding service” either again in batch mode,
or real time via other web-based applications.  I understand the
limitations of this functionality in an open-source environment, namely the
ability of getting decent reference data, but am curious all the same.
Maybe a module could be built that accesses the geocoding services provided
by Google or Yahoo, of MS Virtual Earth??????
Just thought I would throw this out there.
Matthew
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
