[postgis-users] RE: Geocoding
Mark Thomas spatialguru.net at gmail.com
Sat Feb 3 12:21:14 PST 2007
Here's a simple PERL geocoder for Google.
-- $Id: google_geocode.sql 171 2007-01-26 02:35:09Z mark $ --
DROP TABLE google_api_key;
CREATE TABLE google_api_key (
    key text primary key
INSERT INTO google_api_key values ('your key here');
CREATE OR REPLACE FUNCTION geocode(text) returns geometry as $$
declare
    mykey text;
begin
    select key into mykey from google_api_key;
    return GeomFromEWKT(geocode_impl($1, mykey));
end;
$$ language plpgsql;
CREATE OR REPLACE FUNCTION geocode_impl(text, text) returns text as '
   use LWP::Simple;
   $csv = get("http://maps.google.com/maps/geo?output=csv&q=
".$_[0]."&key=".$_[1]);
   @tokens = split(/,/, $csv);
   if ($tokens[0] == "200") {
       return "SRID=4326;POINT(" . $tokens[3] . " " . $tokens[2] . ")";
   } else {
       return "";
' LANGUAGE plperlu IMMUTABLE;
google uses tmerc, so you can call a function like this to get correct SRID
for point and use transform
create or replace function getUTMZoneEPSG(geometry) returns int as $$
declare
    i int := 32600;
    j numeric;
begin
    j := abs((-180 - X($1)) / 6);
    if j < 0.5 then
        j := 1;
    end if;
    i := i + round(j);
    if Y($1) < 0 then
        i := i + 30;
    end if;
    return i;
end;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070203/47cd7032/attachment.html>
