[postgis-users] Geocoding
Mark Thomas
spatialguru.net at gmail.com
Sat Feb 3 12:25:18 PST 2007
As an aside, at the end of this year the census bureau will be relaesing the
TIGER/line files in shapefile format, which should help out working with
it. Just an FYI.
On 2/3/07, postgis-users-request at postgis.refractions.net <
postgis-users-request at postgis.refractions.net> wrote:
> Send postgis-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-users-owner at postgis.refractions.net
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
> 1. Re: Lat/lon bounding box to area? (Paul Ramsey)
> 2. Re: How best to do this? (Mark Thomas)
> 3. Re: Lat/lon bounding box to area? (Mark Thomas)
> 4. Geocoding (Stone, Matthew (DHS-HISP))
> 5. RE: Geocoding (Rob Tester)
> 6. Re: Geocoding (Brad Ediger)
> 7. Re: Geocoding (Brent Pedersen)
> 8. RE: Geocoding (Doug_Newcomb at fws.gov)
> 9. Re: Geocoding (Dan Putler)
> 10. Re: How best to do this? (Mark Cave-Ayland)
> 11. Re: Errors in jdbc rpm build on Fedora Core 6 (Mark Cave-Ayland)
> 12. GEOS 3.0.0rc4 (Paul Ramsey)
> 13. Re: GEOS 3.0.0rc4 (TECHER David)
> 14. Re: Errors in jdbc rpm build on Fedora Core 6 (Devrim GUNDUZ)
> 15. Re: How best to do this? (Stephen Woodbridge)
> Message: 1
> Date: Fri, 02 Feb 2007 11:11:20 -0800
> From: Paul Ramsey <pramsey at refractions.net>
> Subject: Re: [postgis-users] Lat/lon bounding box to area?
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <45C38CD8.5080605 at refractions.net>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> How accurate do you need your area to be? Best bet would be to treat the
> lat/lon "box" as a trapezoid (which more closely approximates its
> "ground shape"). Use distance_sphere or distance_spheroid to calculate
> the metric length of the top and bottom and the height, then basic math
> to calculate the area.
> P
> Steve Benzo wrote:
> > Hi,
> > This might be a stupid question, but is there a way using PostGIS that I
> > can take a bounding box (polyline) supplied by a user (they're drawing a
> > box on the map, from which I get the xmin/ymin/etc from), which I'd like
> > to use to get an area from (utlimately acres). My first step will be to
> > get that polyline into PostGIS (struggling, but should be able to figure
> > it out) and then apply a trigger which populates an area field from
> > that. Thanks in advance.
> > SB
> > Check out the all-new Yahoo! Mail beta
> http://us.rd.yahoo.com/evt=43257/*http://advision.webevents.yahoo.com/mailbeta
> > - Fire up a more powerful email and get things done faster.
> Paul Ramsey
> Refractions Research
> http://www.refractions.net
> Phone: 250-383-3022
> Cell: 250-885-0632
> Message: 2
> Date: Fri, 2 Feb 2007 13:23:35 -0600
> From: "Mark Thomas" <spatialguru.net at gmail.com>
> Subject: Re: [postgis-users] How best to do this?
> To: postgis-users at postgis.refractions.net
> Message-ID:
> <2b5aa3d50702021123x16a45ae7w299bd99146dfd428 at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> For the error with Union, I had this happen yesterday. To solve, I used
> Simplify(geom,<very small number>) before passing to GeomUnion. that
> might
> work for you.
> On 2/2/07, postgis-users-request at postgis.refractions.net <
> > Today's Topics:
> > 1. How best to do this? (Stephen Woodbridge)
> > 2. Re: How best to do this? (Stephen Woodbridge)
> > 3. Re: How best to do this? (Paul Ramsey)
> > 4. Re: pg_restore problem - linked to different versions?
> > (Mark Cave-Ayland)
> > 5. Errors in jdbc rpm build on Fedora Core 6 (Dido)
> > 6. Re: pg_restore problem - linked to different versions?
> > (Stefan Schwarzer)
> > 7. Re: How best to do this? (Stephen Woodbridge)
> > 8. Re: How best to do this? (Paul Ramsey)
> > 9. Lat/lon bounding box to area? (Steve Benzo)
> > Message: 1
> > Date: Thu, 01 Feb 2007 22:34:38 -0500
> > From: Stephen Woodbridge <woodbri at swoodbridge.com>
> > Subject: [postgis-users] How best to do this?
> > Message-ID: <45C2B14E.2070904 at swoodbridge.com>
> > Content-Type: text/plain; charset=UTF-8; format=flowed
> > Hi all,
> > Sorry the subject line is not more useful, but let me explain.
> > 1) I have a set of polgons A and another set of polygon B
> > 2) I need to a new set of polygons C that are the union of
> > A intersect B and A difference B
> > So basically B partially covers A and I want to split polygons in a into
> > the covered piece(s) and that that is not covered.
> > On the surface this is very straight forward, but it isn't ...
> > insert into newtable (....)
> > select ..., intersection(A.the_geom, B.the_geom) as the_geom
> > from A, B
> > where A.the_geom && B.the_geom and
> > intersects(A.the_geom, B.the_geom);
> > This works, but I get a bunch of GEOMETRYCOLLECTION objects in the
> > results and out of 1022 collection I have 2780 additional POLYGONs.
> > So I could do something like:
> > select * from
> > (select ..., (dump(the_geom)).geom as the_geom from newtable
> > where geometrytype(the_geom)='GEOMETRYCOLLECTION' ) as foo
> > where geometrytype(the_geom)='POLYGON';
> > delete from newtable where geometrytype(the_geom)='GEOMETRYCOLLECTION';
> > So now comes the tricky part how do you do the difference? I was
> > thinking I could take A difference newtable but because I have multiple
> > little pieces instead of a single piece, I think I am getting:
> > (A - Part1), (A - Part2), (A - Part3) instead of
> > (A - Part1 - Part2 - Part3)
> > So I think I need to union the polygon pieces from each row that is
> > dumped above. Is that as simple as tossing part of the dump into a
> > geomunion()? How would that look?
> > -Steve W
> > Message: 2
> > Date: Fri, 02 Feb 2007 00:01:39 -0500
> > Message-ID: <45C2C5B3.2020709 at swoodbridge.com>
> > OK, one step forward and two steps backward ...
> > I was about to get rid of my gemetrycollections with:
> > update newtable set the_geom =
> > (select geomunion(geom1) from
> > (select (dump(the_geom)).geom as geom1) as foo
> > where geometrytype(geom1)='POLYGON'
> > This worked very nicely once I figured out that this was the way to
> > solve the problem. So now each geometry collection is converted into a
> > polygon or multipolygon and all the linestring and point artifacts of
> > the intersection are removed.
> > select distinct geometrytype(the_geom) from soils2;
> > POLYGON
> > MULTIPOLYGON
> > select * from soils where not isvalid(the_geom);
> > reports 0 rows
> > insert into newtable (..., the_geom)
> > select A....,
> > difference(A.the_geom, B.the_geom) as the_geom
> > from A, B
> > where A.the_geom && B.the_geom and overlaps(A.the_geom, B.the_geom);
> > NOTICE: TopologyException: no outgoing dirEdge found
> > (287030,892621,892621)
> > ERROR: GEOS difference() threw an error!
> > Now what do I do??? If I have to upgrade it might be easiest to upgrade
> > my WinXP laptop if there is an easy way to do that, then dump and load
> > the data to that.
> > select postgis_full_version();
> > "POSTGIS="1.1.5" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> > USE_STATS (procs from 1.1.1 need upgrade)"
> > select version();
> > "PostgreSQL 8.0.8 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
> > 3.4.2 [FreeBSD] 20040728"
> > -Steve
> > Stephen Woodbridge wrote:
> > > Hi all,
> into
> > > from A, B
> > > select * from
> multiple
> > > -Steve W
> > Message: 3
> > Date: Thu, 1 Feb 2007 21:14:22 -0800
> > Message-ID: <D2E872F9-F43D-41DE-868C-F936776CECAD at refractions.net>
> > Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
> > GEOS 3 does include a number of fixes that will help difference and
> > union.
> > P
> > > into a polygon or multipolygon and all the linestring and point
> > > artifacts of the intersection are removed.
> > > POLYGON
> > > MULTIPOLYGON
> > > reports 0 rows
> > > select A....,
> > > from A, B
> > > upgrade my WinXP laptop if there is an easy way to do that, then
> > > dump and load the data to that.
> > > 2004" USE_STATS (procs from 1.1.1 need upgrade)"
> > > select version();
> > > (GCC) 3.4.2 [FreeBSD] 20040728"
> > > -Steve
> > >> Hi all,
> > >> a into the covered piece(s) and that that is not covered.
> > >> from A, B
> > >> select * from
> > >> multiple little pieces instead of a single piece, I think I am
> > >> getting:
> > >> is dumped above. Is that as simple as tossing part of the dump
> > >> into a geomunion()? How would that look?
> > >> -Steve W
> > Message: 4
> > Date: Fri, 02 Feb 2007 12:25:19 +0000
> > From: Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk>
> > Subject: Re: [postgis-users] pg_restore problem - linked to different
> > versions?
> > Message-ID: <1170419119.6358.10.camel at mca-desktop>
> > On Thu, 2007-02-01 at 14:40 +0100, Stefan Schwarzer wrote:
> > > Hi,
> > > I dumped my locally newly created database and wanted to restore on
> > > the server. But I got this message.
> > > pg_restore: [archiver] unsupported version (1.10) in file header
> > > pg_restore call failed
> > > I guess the problem comes from the fact that:
> > > the server runs with PostGres 8.1.0 and PostGIS 1.1.2
> > > my local machine with PostGres 8.1.2 and PostGIS 1.1.1
> > > Could that be? And what can I do to solve the problem? In the moment
> > > we won't touch our server, as it runs smoothly. And on my local
> > > machine, a Mac, the different packages have been installed via the
> > > prebuild packages from KyngChaos. I am no compiler.... So, not too
> > > keen to re-compile Postgres and Postgis.... But I guess it's what I
> > > have to do, right?
> > > Thanks for any hints...
> > Hi Stefan,
> > Could it be that you have multiple versions of pg_restore on your
> > server? Looking at the PostgreSQL source code, version 1.10 headers were
> > introduced with the advent of tablespaces (PostgreSQL 8.0) and so you
> > are attempting to restore your pg_dump with a pg_restore for PostgreSQL
> > < 8.0.
> > So you need to check your paths and make sure you are using the
> > pg_restore from your PostgreSQL 8.1 installation. Perhaps if you
> > installed PostgreSQL 8.1 yourself, you need to be using the version
> > in /usr/local/bin rather than the version in /usr/bin which originally
> > came with your distro?
> > Kind regards,
> > Mark.
> > Message: 5
> > Date: Fri, 02 Feb 2007 16:04:01 +0200
> > From: Dido <dido+postgis at sarge.mine.nu>
> > Subject: [postgis-users] Errors in jdbc rpm build on Fedora Core 6
> > Message-ID: <20070202160401.03ovwnsug400s8og at mx2.sofita.com>
> > charset=UTF-8; DelSp="Yes"; format="flowed"
> > Hi @,
> > I'm trying to make postgis 1.2.1 Fedora Core 6 rpm package, but I have
> > some errors.
> > Also I would like to make postgis rpm against postgresql 8.2.1 , did
> > someone have feedback ?
> > Here is list of postgres and java packages:
> > [root at fc-test ~]# rpm -qa | grep postgres
> > postgresql-server-8.1.6-1.fc6
> > postgresql-docs-8.1.6-1.fc6
> > postgresql-8.1.6-1.fc6
> > postgresql-devel-8.1.6-1.fc6
> > postgresql-libs-8.1.6-1.fc6
> > postgresql-contrib-8.1.6-1.fc6
> > postgresql-jdbc-8.1.407-1jpp.4
> > [root at fc-test ~]# rpm -qa | grep java
> > java-1.4.2-gcj-compat-1.4.2.0-40jpp.110
> > gcc-java-4.1.1-51.fc6
> > java-1.4.2-gcj-compat-devel-1.4.2.0-40jpp.110
> > I'm using following SPEC file from 1.2.0, with version change
> > [root at fc-test ~]# cat /usr/src/redhat/SPECS/postgis.spec
> > %{!?javabuild:%define javabuild 1}
> > %{!?utils:%define utils 1}
> > %{!?gcj_support:%define gcj_support 1}
> > Summary: Geographic Information Systems Extensions to PostgreSQL
> > Version: 1.2.1
> > Release: 2%{?dist}
> > License: GPL
> > Group: Applications/Databases
> > Source0:
> > http://postgis.refractions.net/download/%{name}-%{version}.tar.gz
> > Source4: filter-requires-perl-Pg.sh
> > #Patch1: postgis-configure.patch
> > Patch2: postgis-javamakefile.patch
> > URL: http://postgis.refractions.net/
> BuildRoot: %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u}
> > -n)
> > BuildRequires: postgresql-devel, proj-devel, geos-devel, byacc,
> > proj-devel, flex, postgresql-jdbc
> > Requires: postgresql, geos, proj
> > %description
> > PostGIS adds support for geographic objects to the PostgreSQL
> > object-relational
> > database. In effect, PostGIS "spatially enables" the PostgreSQL server,
> > allowing it to be used as a backend spatial database for geographic
> > information
> > systems (GIS), much like ESRI's SDE or Oracle's Spatial extension.
> PostGIS
> > follows the OpenGIS "Simple Features Specification for SQL" and has been
> > certified as compliant with the "Types and Functions" profile.
> > %if %javabuild
> > %package jdbc
> > Summary: The JDBC driver for PostGIS
> > License: LGPL
> > Requires: postgis
> > BuildRequires: ant >= 0:1.6.2, junit >= 0:3.7
> > %if %{gcj_support}
> > BuildRequires: gcc-java
> > Requires(post): java-1.4.2-gcj-compat
> > Requires(postun): java-1.4.2-gcj-compat
> > %endif
> > %description jdbc
> > The postgis-jdbc package provides the essential jdbc driver for PostGIS.
> > %endif
> > %if %utils
> > %package utils
> > Summary: The utils for PostGIS
> > Requires: postgis, perl-DBD-Pg
> > %description utils
> > The postgis-utils package provides the utilities for PostGIS.
> > %endif
> > %define __perl_requires %{SOURCE4}
> > %prep
> > %setup -q
> > #%patch1 -p0
> > %patch2 -p0
> > %build
> > %configure
> > make %{?_smp_mflags} LPATH=`pg_config --pkglibdir` shlib="%{name}.so"
> > %if %javabuild
> > export MAKEFILE_DIR=%{_builddir}/%{name}-%{version}/java/jdbc
> > JDBC_VERSION_RPM=`rpm -ql postgresql-jdbc| grep 'jdbc.jar$'|awk -F '/'
> > '{print $5}'`
> > sed 's/postgresql.jar/'${JDBC_VERSION_RPM}'/g' $MAKEFILE_DIR/Makefile
> > > $MAKEFILE_DIR/Makefile.new
> > mv -f $MAKEFILE_DIR/Makefile.new $MAKEFILE_DIR/Makefile
> > make -C java/jdbc
> > %endif
> > %if %utils
> > make -C utils
> > %endif
> > %install
> > rm -rf %{buildroot}
> > make install DESTDIR=%{buildroot}
> > install -d %{buildroot}%{_libdir}/pgsql/
> > install lwgeom/liblwgeom.so* %{buildroot}%{_libdir}/pgsql/
> > install -d %{buildroot}%{_datadir}/pgsql/contrib/
> > install -m 644 *.sql %{buildroot}%{_datadir}/pgsql/contrib/
> > rm -f %{buildroot}%{_libdir}/liblwgeom.so*
> > rm -f %{buildroot}%{_datadir}/*.sql
> > %if %javabuild
> > install -d %{buildroot}%{_javadir}
> > install -m 755 java/jdbc/%{name}_%{version}.jar %{buildroot}%{_javadir}
> > %if %{gcj_support}
> > aot-compile-rpm
> > %endif
> > %endif
> > strip %{buildroot}/%{_libdir}/gcj/%{name}/*.jar.so
> > %if %utils
> > install -d %{buildroot}%{_datadir}/%{name}
> > install -m 644 utils/*.pl %{buildroot}%{_datadir}/%{name}
> > %endif
> > %clean
> > rm -rf %{buildroot}
> > %post -p %{_bindir}/rebuild-gcj-db
> > %postun -p %{_bindir}/rebuild-gcj-db
> > %files
> > %defattr(-,root,root)
> > %doc COPYING CREDITS NEWS TODO README.%{name} TODO doc/html
> > loader/README.* doc/%{name}.xml doc/ZMSgeoms.txt
> > %attr(755,root,root) %{_bindir}/*
> > %attr(755,root,root) %{_libdir}/pgsql/liblwgeom.so*
> > %{_datadir}/pgsql/contrib/*.sql
> > %if %javabuild
> > %files jdbc
> > %doc java/jdbc/COPYING_LGPL java/jdbc/README
> > %attr(755,root,root) %{_javadir}/%{name}_%{version}.jar
> > %if %{gcj_support}
> > %dir %{_libdir}/gcj/%{name}
> > %{_libdir}/gcj/%{name}/*.jar.db
> > %endif
> > %endif
> > %if %utils
> > %files utils
> > %doc utils/README
> > %attr(755,root,root) %{_datadir}/%{name}/test_estimation.pl
> > %attr(755,root,root) %{_datadir}/%{name}/profile_intersects.pl
> > %attr(755,root,root) %{_datadir}/%{name}/test_joinestimation.pl
> > %attr(644,root,root) %{_datadir}/%{name}/create_undef.pl
> > %attr(644,root,root) %{_datadir}/%{name}/%{name}_proc_upgrade.pl
> > %attr(644,root,root) %{_datadir}/%{name}/%{name}_restore.pl
> > %endif
> > %changelog
> > * Mon Dec 26 2006 - Devrim GUNDUZ <devrim at commandprompt.com> 1.2.0-2
> > - More spec file fixes per bugzilla review #220743
> > ----------------------------------------------------- errors log here:
> > + make -C java/jdbc
> > 1. ERROR in ./src/org/postgis/ComposedGeom.java (at line 29)
> > import org.postgresql.util.PGtokenizer;
> > The import org.postgresql.util cannot be resolved
> > 2. ERROR in ./src/org/postgis/ComposedGeom.java (at line 104)
> > PGtokenizer t = new PGtokenizer(PGtokenizer.removePara(value),
> > PGtokenizer cannot be resolved to a type
> > 3. ERROR in ./src/org/postgis/ComposedGeom.java (at line 104)
> > 4. ERROR in ./src/org/postgis/ComposedGeom.java (at line 104)
> > 5. ERROR in ./src/org/postgis/DriverWrapper.java (at line 72)
> > public class DriverWrapper extends Driver {
> > Driver cannot be resolved to a type
> > 6. ERROR in ./src/org/postgis/DriverWrapperAutoprobe.java (at line 54)
> > public class DriverWrapperAutoprobe extends DriverWrapper {
> > The hierarchy of the type DriverWrapperAutoprobe is inconsistent
> > 7. ERROR in ./src/org/postgis/DriverWrapperLW.java (at line 49)
> > public class DriverWrapperLW extends DriverWrapper {
> > The hierarchy of the type DriverWrapperLW is inconsistent
> > 8. ERROR in ./src/org/postgis/PGbox2d.java (at line 31)
> > public class PGbox2d extends PGboxbase {
> > The hierarchy of the type PGbox2d is inconsistent
> > 9. ERROR in ./src/org/postgis/PGbox3d.java (at line 32)
> > public class PGbox3d extends PGboxbase {
> > The hierarchy of the type PGbox3d is inconsistent
> > 10. ERROR in ./src/org/postgis/PGboxbase.java (at line 40)
> > public abstract class PGboxbase extends PGobject {
> > PGobject cannot be resolved to a type
> > 11. ERROR in ./src/org/postgis/PGgeometry.java (at line 34)
> > public class PGgeometry extends PGobject {
> > 12. ERROR in ./src/org/postgis/PGgeometryLW.java (at line 37)
> > public class PGgeometryLW extends PGgeometry {
> > The hierarchy of the type PGgeometryLW is inconsistent
> > 13. ERROR in ./src/org/postgis/java2d/Java2DWrapper.java (at line 50)
> > public class Java2DWrapper extends Driver {
> > 14. ERROR in ./src/org/postgis/java2d/PGShapeGeometry.java (at line 63)
> > public class PGShapeGeometry extends PGobject implements Shape
> > 14 problems (14 errors)make: *** [compile] Error 255
> > error: Bad exit status from /var/tmp/rpm-tmp.18862 (%build)
> > How I can tackle with this situation ?
> > Best regards,
> > Dido
> > Message: 6
> > Date: Fri, 2 Feb 2007 15:27:33 +0100
> > From: Stefan Schwarzer <stefan.schwarzer at grid.unep.ch>
> > versions?
> > Message-ID: <85D74A20-1E59-4D92-A4D4-57DD74CAF1B1 at grid.unep.ch>
> > >> have to do, right?
> > > Hi Stefan,
> > > were
> > > PostgreSQL
> > > < 8.0.
> > Great Mark,
> > you were absolutely right! There were two or three references to
> > pg_restore; only one of them version 8, and not the default one.
> > Thanks a lot!!!
> > Message: 7
> > Date: Fri, 02 Feb 2007 12:03:37 -0500
> > Message-ID: <45C36EE9.6050403 at swoodbridge.com>
> > Paul, et al,
> > Any chance that someone would have GEOS 3 built for WinXP that I could
> > drop into a system currently running:
> > "POSTGIS="1.1.3" GEOS="2.2.2-CAPI-1.1.0" PROJ="Rel. 4.4.9, 29 Oct 2004"
> > USE_STATS"
> > "PostgreSQL 8.1.4 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
> > 3.4.2 (mingw-special)"
> > So I could give this a try.
> > In the past, I seem to remember people dealing with these problems using
> > snaptogrid() - would this potentially help here and how would I change
> > my query to use that?
> > -Steve
> > union.
> > > P
> a
> > >> POLYGON
> > >> MULTIPOLYGON
> > >> reports 0 rows
> > >> select A....,
> > >> from A, B
> > >> upgrade my WinXP laptop if there is an easy way to do that, then dump
> > >> select version();
> (GCC)
> > >> -Steve
> > >>> Hi all,
> > >>> from A, B
> > >>> select * from
> > getting:
> > >>> -Steve W
> > Message: 8
> > Date: Fri, 02 Feb 2007 09:25:43 -0800
> > Message-ID: <45C37417.4070607 at refractions.net>
> > snaptogrid might help, it is a crude hammer similar in many ways to the
> > more subtle approaches in GEOS3.
> > Because the C API didn't change between versions, you may be able to
> > simply copy a suitably compiled geos DLL into place, perhaps by
> > stripping one out of the windows downloads. I don't actually know if our
> > windows downloads are using GEOS3 though... hrm. Mark CA?
> > P
> > > Paul, et al,
> could
> 2004"
> > > USE_STATS"
> using
> > > -Steve
> > >> union.
> > >> P
> > >>> a polygon or multipolygon and all the linestring and point artifacts
> > >>> POLYGON
> > >>> MULTIPOLYGON
> > >>> reports 0 rows
> > >>> select A....,
> > >>> from A, B
> dump
> > >>> select version();
> > >>> -Steve
> > >>>> Hi all,
> > >>>> from A, B
> > >>>> select * from
> > getting:
> > >>>> -Steve W
> > Paul Ramsey
> > Phone: 250-383-3022
> > Cell: 250-885-0632
> > Message: 9
> > Date: Fri, 2 Feb 2007 10:40:36 -0800 (PST)
> > From: Steve Benzo <steve_benzo at yahoo.com>
> > Subject: [postgis-users] Lat/lon bounding box to area?
> > Message-ID: <404830.54155.qm at web56205.mail.re3.yahoo.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Hi,
> box
> > on the map, from which I get the xmin/ymin/etc from), which I'd like to
> use
> > to get an area from (utlimately acres). My first step will be to get
> that
> > polyline into PostGIS (struggling, but should be able to figure it out)
> and
> > then apply a trigger which populates an area field from that. Thanks in
> > advance.
> > SB
> > Check out the all-new Yahoo! Mail beta - Fire up a more powerful email
> and
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/13939878/attachment-0001.html
> > End of postgis-users Digest, Vol 52, Issue 2
> Regards,
> Mark Thomas
> 205.529.9013
> "Commit to the Lord whatever you do,
> and your plans will succeed." - Proverbs 16:3
> URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/cad711fa/attachment-0001.html
> Message: 3
> Date: Fri, 2 Feb 2007 13:24:56 -0600
> Subject: [postgis-users] Re: Lat/lon bounding box to area?
> Message-ID:
> <2b5aa3d50702021124n3e99215fxfeb2080e2d7a0f82 at mail.gmail.com>
> Sure, use GeomFromText or GeomFromEWKT and pass in WKT for a polygon
> defined
> by the bbox
> > Today's Topics:
> > (Mark Cave-Ayland)
> > (Stefan Schwarzer)
> > Message: 1
> > Hi all,
> > from A, B
> > select * from
> > -Steve W
> > Message: 2
> > POLYGON
> > MULTIPOLYGON
> > reports 0 rows
> > select A....,
> > from A, B
> > the data to that.
> > select version();
> > -Steve
> > > Hi all,
> into
> > > from A, B
> > > select * from
> multiple
> > > -Steve W
> > Message: 3
> > union.
> > P
> > > POLYGON
> > > MULTIPOLYGON
> > > reports 0 rows
> > > select A....,
> > > from A, B
> > > select version();
> > > -Steve
> > >> Hi all,
> > >> from A, B
> > >> select * from
> > >> getting:
> > >> -Steve W
> > Message: 4
> > versions?
> > > Hi,
> > > have to do, right?
> > Hi Stefan,
> > < 8.0.
> > Kind regards,
> > Mark.
> > Message: 5
> > Hi @,
> > some errors.
> > Version: 1.2.1
> > Release: 2%{?dist}
> > License: GPL
> > Source0:
> > -n)
> > %description
> > object-relational
> > information
> PostGIS
> > %if %javabuild
> > %package jdbc
> > License: LGPL
> > Requires: postgis
> > %if %{gcj_support}
> > %endif
> > %description jdbc
> > %endif
> > %if %utils
> > %package utils
> > %description utils
> > %endif
> > %prep
> > %setup -q
> > #%patch1 -p0
> > %patch2 -p0
> > %build
> > %configure
> > %if %javabuild
> > '{print $5}'`
> > make -C java/jdbc
> > %endif
> > %if %utils
> > make -C utils
> > %endif
> > %install
> > rm -rf %{buildroot}
> > %if %javabuild
> > %if %{gcj_support}
> > aot-compile-rpm
> > %endif
> > %endif
> > %if %utils
> > %endif
> > %clean
> > rm -rf %{buildroot}
> > %files
> > %if %javabuild
> > %files jdbc
> > %if %{gcj_support}
> > %endif
> > %endif
> > %if %utils
> > %files utils
> > %doc utils/README
> > %endif
> > %changelog
> > + make -C java/jdbc
> > Best regards,
> > Dido
> > Message: 6
> > versions?
> > >> have to do, right?
> > > Hi Stefan,
> > > were
> > > PostgreSQL
> > > < 8.0.
> > Great Mark,
> > Thanks a lot!!!
> > Message: 7
> > Paul, et al,
> > USE_STATS"
> > -Steve
> > union.
> > > P
> a
> > >> POLYGON
> > >> MULTIPOLYGON
> > >> reports 0 rows
> > >> select A....,
> > >> from A, B
> > >> select version();
> (GCC)
> > >> -Steve
> > >>> Hi all,
> > >>> from A, B
> > >>> select * from
> > getting:
> > >>> -Steve W
> > Message: 8
> > P
> > > Paul, et al,
> could
> 2004"
> > > USE_STATS"
> using
> > > -Steve
> > >> union.
> > >> P
> > >>> POLYGON
> > >>> MULTIPOLYGON
> > >>> reports 0 rows
> > >>> select A....,
> > >>> from A, B
> dump
> > >>> select version();
> > >>> -Steve
> > >>>> Hi all,
> > >>>> from A, B
> > >>>> select * from
> > getting:
> > >>>> -Steve W
> > Paul Ramsey
> > Phone: 250-383-3022
> > Cell: 250-885-0632
> > Message: 9
> > Hi,
> box
> use
> that
> and
> > advance.
> > SB
> and
> > URL:
> Regards,
> Mark Thomas
> 205.529.9013
> URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/426bc9a4/attachment-0001.html
> Message: 4
> Date: Fri, 2 Feb 2007 12:15:05 -0800
> From: "Stone, Matthew (DHS-HISP)" <MStone at dhs.ca.gov>
> Subject: [postgis-users] Geocoding
> To: <postgis-users at postgis.refractions.net>
> Message-ID:
> 0C2255FE8998DB47858A79FC0F966B8D0196F1A2 at dhsexcmsg13.intra.dhs.ca.gov>
> Content-Type: text/plain; charset="us-ascii"
> Does/Will PostGis have a Geocoding routine built in such as ArcSDE has
> locators and geocoding processing? I am curious, as geocoding is the
> building block of any GIS work I do and I have need of decent
> open-source solutions that can process millions of records in a batch
> mode, or can be implemented on the WEB as a "geocoding service" either
> again in batch mode, or real time via other web-based applications. I
> understand the limitations of this functionality in an open-source
> environment, namely the ability of getting decent reference data, but am
> curious all the same.
> Maybe a module could be built that accesses the geocoding services
> provided by Google or Yahoo, of MS Virtual Earth??????
> Just thought I would throw this out there.
> Matthew
> Matthew Stone, MPH
> UCSF/CA Dept. of Health Services
> Health Information & Strategic Planning (HISP)
> Office of County Health Services (OCHS)
> 1501 Capitol Ave MS 5204
> Mailing Address:
> PO BOX 997413, MS 5204
> Sacramento CA 95899-7413
> Physical Address:
> 1501 Capitol Avenue, Suite 71.5195, MS 5204
> Sacramento, CA 95814
> PH: 916-552-9918
> FAX: 916-552-8260
> mstone at dhs.ca.gov
> URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/eba2bba7/attachment-0001.html
> Message: 5
> Date: Fri, 2 Feb 2007 13:29:48 -0700
> From: "Rob Tester" <robtester at gmail.com>
> Subject: RE: [postgis-users] Geocoding
> To: "'PostGIS Users Discussion'"
> Message-ID: <00b801c74708$e3a9e060$aafda120$@com>
> I think that the task of geocoding is fairly easy and I have written a
> geocode function that uses PostGIS. However, the problem is where to get
> the
> data. In the U.S. you can use Tiger line data from the census, but it is
> horrible inaccurate. If you have resources you can purchase more accurate
> data from other companies like Navteq, or manually correct the census
> data.
> Rob.
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stone,
> Matthew (DHS-HISP)
> Sent: Friday, February 02, 2007 1:15 PM
> building block of any GIS work I do and I have need of decent open-source
> solutions that can process millions of records in a batch mode, or can be
> implemented on the WEB as a "geocoding service" either again in batch
> mode,
> or real time via other web-based applications. I understand the
> limitations
> of this functionality in an open-source environment, namely the ability of
> getting decent reference data, but am curious all the same.
> provided
> Matthew
> Matthew Stone, MPH
> Mailing Address:
> Physical Address:
> PH: 916-552-9918
> FAX: 916-552-8260
> URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/5dad45ee/attachment-0001.html
> Message: 6
> Date: Fri, 2 Feb 2007 14:39:10 -0600
> From: Brad Ediger <brad at bradediger.com>
> Subject: Re: [postgis-users] Geocoding
> Message-ID: <AA104CF0-B584-4BC9-8619-75D9CDA0D763 at bradediger.com>
> Content-Type: text/plain; charset="windows-1252"
> Skipped content of type multipart/alternative-------------- next part
> A non-text attachment was scrubbed...
> Type: application/pkcs7-signature
> Desc: not available
> Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070202/025cf519/smime-0001.bin
> Message: 7
> Date: Fri, 2 Feb 2007 12:44:36 -0800 (PST)
> From: Brent Pedersen <bpederse at nature.Berkeley.EDU>
> Message-ID: <Pine.SOC.4.64.0702021241330.5318 at nature.Berkeley.EDU>
> Content-Type: text/plain; charset="x-unknown"
> this is perhaps not useful if you've already written your own geocoder,
> but there's a python module geopy which lets you use any of the web
> geocoding services (yahoo,google,geocoder.us,etc.) to do geocoding.
> one could probably call that from postgres via PL/Python.
> -brent
> On Fri, 2 Feb 2007, Brad Ediger wrote:
> > Yes, the TIGER/Line data can be horribly inaccurate, and the Navteq/Tele
> > Atlas data is horribly expensive.
> > Google Maps provides a geocoder web service
> > (http://www.google.com/apis/maps/documentation/#Geocoding_Examples) via
> HTTP
> > but it is rate-limited to 50,000 requests per day. They have some
> > commercial-use restrictions, IIRC, and you can't use any of the GMaps
> > services for real-time tracking. But it might fit the bill.
> > Their commercial-use service is pretty darn expensive, too. Starts at
> $10,000
> > per year and goes up from there.
> > hth,
> > Brad
> get
> >> the data. In the U.S. you can use Tiger line data from the census, but
> it
> >> is horrible inaccurate. If you have resources you can purchase more
> >> accurate data from other companies like Navteq, or manually correct the
> >> census data.
> >> Rob.
> Stone,
> >> Matthew (DHS-HISP)
> open-source
> be
> >> implemented on the WEB as a �geocoding service� either again in batch
> mode,
> >> limitations of this functionality in an open-source environment, namely
> the
> >> ability of getting decent reference data, but am curious all the same.
> provided
> >> Matthew
> >> Matthew Stone, MPH
> >> Mailing Address:
> >> Physical Address:
> >> PH: 916-552-9918
> >> FAX: 916-552-8260
> Message: 8
> Date: Fri, 2 Feb 2007 16:05:54 -0500
> From: Doug_Newcomb at fws.gov
> Message-ID:
> <OFD7B82F01.2C98618F-ON85257276.0071C793-85257276.0073E591 at fws.gov
> The Tiger data is getting better. At least here in North Carolina, the
> Census Bureau is working with the local county governments to produce an
> enhanced TIGER dataset . 7.6 meter accuracy for roads. They want to be
> done by 2008.
> Related links below.
> http://www.census.gov/geo/www/tiger/future/future_tl.html
> http://www.census.gov/geo/mtep_obj2/mtr.html
> http://72.14.209.104
> /search?q=cache:RsQ3w_Wgn9EJ:
> wagic.wa.gov/Presentations03/Aug18/MB082103%2520WAGIC%2520MTEP%2520Update.ppt+census+TIGER+enhanced&hl=en&ct=clnk&cd=36&gl=us&client=firefox-a
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
> I left my signature file in /dev/null
> "Rob Tester"
> com> To
> Sent by: "'PostGIS Users Discussion'"
> postgis-users-bou <postgis-users at postgis.refractions.
> nces at postgis.refr net>
> actions.net cc
> Subject
> 02/02/2007 03:29 RE: [postgis-users] Geocoding
> PM
> Please respond to
> PostGIS Users
> Discussion
> stgis.refractions
> .net>
> the data. In the U.S. you can use Tiger line data from the census, but it
> census data.
> Rob.
> Matthew (DHS-HISP)
> mode,
> the
> provided
> Matthew
> Matthew Stone, MPH
> Mailing Address:
> Physical Address:
> PH: 916-552-9918
> FAX: 916-552-8260
> Message: 9
> Date: Fri, 2 Feb 2007 13:23:43 -0800
> From: "Dan Putler" <putler at sauder.ubc.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Message-ID: <E7DA921F-3E7B-4733-83AF-3D7150B84CFC at sauder.ubc.ca>
> Content-Type: text/plain; format=flowed; delsp=yes;
> charset="WINDOWS-1252"
> While not PostGIS based, there is C-based PAGC (www.pagcgeo.org) that
> does do batch geocoding, and could be configured to run under CGI as
> a web based application. PAGC is designed to work with shapefile
> sets, and can be easily customized to work with any address ranged
> road network file (albeit, less customization will be needed for US
> and Canadian layers).
> There are problems with TIGER/Line, but its performance is actually
> not that much worse than commercial products. The following link may
> be of some interest on this:
> http://lagic.lsu.edu/LGISC/Presentations/2005/LGISC-PRES-20050420-
> Geocoding_Evaluation.pdf
> In terms of commercial products, a road network layer for a single
> state runs around $1000 to $1500.
> Dan
> > Tele Atlas data is horribly expensive.
> > Google Maps provides a geocoder web service (http://www.google.com/
> > apis/maps/documentation/#Geocoding_Examples) via HTTP but it is
> > rate-limited to 50,000 requests per day. They have some commercial-
> > use restrictions, IIRC, and you can't use any of the GMaps services
> > at $10,000 per year and goes up from there.
> > hth,
> > Brad
> >> written a geocode function that uses PostGIS. However, the problem
> >> is where to get the data. In the U.S. you can use Tiger line data
> >> from the census, but it is horrible inaccurate. If you have
> >> resources you can purchase more accurate data from other companies
> >> like Navteq, or manually correct the census data.
> >> Rob.
> >> Of Stone, Matthew (DHS-HISP)
> >> has locators and geocoding processing? I am curious, as geocoding
> >> is the building block of any GIS work I do and I have need of
> >> decent open-source solutions that can process millions of records
> >> in a batch mode, or can be implemented on the WEB as a �geocoding
> >> service� either again in batch mode, or real time via other web-
> >> based applications. I understand the limitations of this
> >> Matthew
> >> Matthew Stone, MPH
> >> Mailing Address:
> >> Physical Address:
> >> PH: 916-552-9918
> >> FAX: 916-552-8260
> Message: 10
> Date: Fri, 02 Feb 2007 22:09:13 +0000
> Message-ID: <1170454153.19577.4.camel at mca-desktop>
> > P
> All the Windows downloads are currently using GEOS 2.2.3, although more
> people are beginning to ask about GEOS3. If a GEOS3 RC4 comes out that
> would compile cleanly on Win32, I'd consider coming up with some form of
> test installer - the extra usage may help find those tricky last minute
> bugs before release.
> Kind regards,
> Mark.
> Message: 11
> Date: Fri, 02 Feb 2007 22:11:52 +0000
> Subject: Re: [postgis-users] Errors in jdbc rpm build on Fedora Core 6
> Message-ID: <1170454312.19577.8.camel at mca-desktop>
> > Best regards,
> > Dido
> Hi Dido,
> This is a known issue which is fixed in current SVN. I can't remember
> off the top of my head the exact patch, but you should be able to find
> it in the postgis-commit list archives.
> HTH,
> Mark.
> Message: 12
> Date: Fri, 02 Feb 2007 17:24:43 -0800
> Subject: [postgis-users] GEOS 3.0.0rc4
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>,
> GEOS Development List <geos-devel at geos.refractions.net>
> Message-ID: <45C3E45B.1050906 at refractions.net>
> I have wrapped up an rc4 with January's bug fixes.
> http://geos.refractions.net/geos-3.0.0rc4.tar.bz2
> our
> >> P
> Paul Ramsey
> Phone: 250-383-3022
> Cell: 250-885-0632
> Message: 13
> Date: Sat, 03 Feb 2007 08:45:29 +0100
> From: TECHER David <davidtecher at yahoo.fr>
> Subject: Re: [postgis-users] GEOS 3.0.0rc4
> Message-ID: <45C43D99.6000001 at yahoo.fr>
> Hi Paul, Marc and PostGIS users
> I've tried to compil it for MinGW/Msys
> I don't succeed (problem from ld.exe )
> But I succeed if I used the idea from MCA done in this e-mail
> http://geos.refractions.net/pipermail/geos-devel/2007-January/002767.html
> Sorry I don't try the ideas form the following e-mails
> http://geos.refractions.net/pipermail/geos-devel/2007-January/002769.html
> and so on...
> I think Marc that your idea from
> http://geos.refractions.net/pipermail/geos-devel/2007-January/002781.html
> is good.
> Paul Ramsey a �crit :
> >>> the more subtle approaches in GEOS3.
> >>> our windows downloads are using GEOS3 though... hrm. Mark CA?
> >>> P
> >> All the Windows downloads are currently u...
> [Message clipped]
Regards,
Mark Thomas
205.529.9013
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070203/b4949c9f/attachment.html>
