[postgis-users] Join Help
Paul Ramsey pramsey at refractions.net
Sun Feb 4 09:19:36 PST 2007
I think you want to take everything in A and remove all the things
that have interactions with B. So, loosely:
select * from A where A.id not in (select A.id where A.geom && B.geom);
There is probably a more efficient formulation using the SQL EXCEPT
clause.
P
On 4-Feb-07, at 9:13 AM, Stephen Woodbridge wrote:
> Hi,
> How do a construct a query to count the number of polygons in table
> a the have no interaction with any polygon in table b?
> select count(*) from a, b where not a.the_geom && b.the_geom
> is not it. This seems to count all the polygons in b that do not
> interact with the polygons in a.
> So if a has one polygon and b has 100, then the count(*) would be
> 100 if the polygon in a did not interact with any of the polygons
> in b. Or that is at least what I surmise based on the numbers I'm
> seeing.
> Ideas?
> -Steve
> postgis-users mailing list
