[postgis-users] Join Help
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Feb 4 11:55:22 PST 2007
Great! Thanks Paul, that did the trick.
I have also been able to circumvent the numerics problem. It seems that
if I aways work with my source data I don't have a problem, but if I try
to reuse the intersection() results in a subsequent difference() I run
into the numerics problem I posted about earlier.
As always, I appreciate the great product and the support from the list.
I look forward to working with GEOS 3 also.
Thanks,
-Steve
Paul Ramsey wrote:
> I think you want to take everything in A and remove all the things that
> have interactions with B. So, loosely:
> select * from A where A.id not in (select A.id where A.geom && B.geom);
> There is probably a more efficient formulation using the SQL EXCEPT clause.
> P
> On 4-Feb-07, at 9:13 AM, Stephen Woodbridge wrote:
>> Hi,
>> How do a construct a query to count the number of polygons in table a
>> the have no interaction with any polygon in table b?
>> select count(*) from a, b where not a.the_geom && b.the_geom
>> is not it. This seems to count all the polygons in b that do not
>> interact with the polygons in a.
>> So if a has one polygon and b has 100, then the count(*) would be 100
>> if the polygon in a did not interact with any of the polygons in b. Or
>> that is at least what I surmise based on the numbers I'm seeing.
>> Ideas?
>> -Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
