[postgis-users] Re: USGS NHD data to PostGIS
Randy George rkgeorge at cadmaps.com
Mon Feb 5 16:42:57 PST 2007
	I've investigated my NHD data problem a little further. Looking at
the NHDArea table of the mdb it appears that the Shape field's internal
'Shape Type' is listed as 19. Unless there has been a recent change, I don't
think the shp format has a type 19.
I ran a test conversion to svg forcing .shp type 19 to a type 5 (Polygon)
and I get valid polygon <paths>?
Has ESRI added an additional "Shape Type" to the list? Or is there some
issue with NHD geodatabases?
If 19 is unknown to the ogr translator that would explain the empty geometry
columns and sporadic empty geometry fields. It would also explain why there
is no error since those records would simply be created with no geometry.
http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
Value Shape Type
0 Null Shape
1 Point
3 PolyLine
5 Polygon
8 MultiPoint
11 PointZ
13 PolyLineZ
15 PolygonZ
18 MultiPointZ
21 PointM
23 PolyLineM
25 PolygonM
28 MultiPointM
31 MultiPatch
Thanks
Randy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Randy
George
Sent: Monday, February 05, 2007 3:30 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Re: USGS NHD data to PostGIS
Thanks for the pointer.
However, all I could find were pointers to personal geodatabase or
NHDGeoinArc export. Of course the geodatabase contains shape format geometry
fields in each record. Perhaps I'm stumbling over the interface.
Is there a public OGC WFS/WMS behind the Esri interface?
That would be ideal for my interest, since I wouldn't have to host the NHD
locally.
Thanks
Randy
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Reid
Priedhorsky
Sent: Monday, February 05, 2007 3:08 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Re: USGS NHD data to PostGIS
Randy George wrote:
> Hi,
>             As an experiment I'm attempting to import USGS NHD data
> ftp://nhdftp.usgs.gov/SubRegions/  into PostGIS. The NHD data comes as
ESRI
> geodatabase .mdb files. I was glad to see that ogr2ogr now supports ESRI
> geodatabase mdb format, so I tried using ogr2ogr 1.4.0 in FWTools 1.1.3,
but
> ran into some problems.
Hi Randy,
I don't know how to fix your problem, but at
<http://nhdgeo.usgs.gov/viewer.htm>, you can download NHD data in
Shapefile format. Does that meet your needs?
Take care,
Reid
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
