[postgis-users] Postgis and ArcGIS
Tim Bowden tim.bowden at westnet.com.au
Fri Feb 9 05:08:28 PST 2007
On Fri, 2007-02-09 at 09:00 +0100, Uwe Seher wrote:
> Am 09.02.2007, 05:14 Uhr, schrieb Tim Bowden <tim.bowden at westnet.com.au>:
> > Hi all,
> > I'm looking for the best way of allowing interaction between PostGIS on
> > the back end and ArcGIS on the desktop.  Something like PgArc would be
> > good, but obviously very difficult to implement :-(
> > There is avpgcon which supports ArcView 3.x (only?).  Is anyone able to
> > shed any light on other options or report success with either of these
> > options?  Can any of the ArcGIS stuff do wfs-t thereby allowing us to
> > put geoserver in as an interface?
> > Thanks,
> > Tim Bowden
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Hi!
> You can try this (http://gforge2.uwc.ac.za/projects/ziggis/), but it seems
> that there is not very much going. I think the problem in connecting
> PostGIS and ArcGIS is in the ArcObjects workspaces to handle the
> Datasource. As a Workaround you can use a tempoprary shapefile like pgArc
> or you can setup a WMS. A WFS should also work, althought i didn't test
> it. Or you can use something other than ArcGIS. Our way at the moment is
> to separate workingareas as a shapefile and update them, when finished.
> CU Uwe Seher
Thanks,
I was hoping someone had some better news.
Regards,
Tim Bowden
