[postgis-users] within_distance function
Obe, Regina
robe.dnd at cityofboston.gov
Mon Feb 12 05:54:25 PST 2007
Great suggestion Paul! My SQL function is running just as fast as the
expand combination in my code.
My sql function looks like this
CREATE OR REPLACE FUNCTION within_distancesql(geom1 geometry, geom2
geometry, dist double precision)
RETURNS boolean AS
$BODY$
SELECT (expand($1, $3) && $2 AND distance($1, $2) <= $3) ;
$BODY$
LANGUAGE 'sql' IMMUTABLE;
First I realized that I had my queries backward and I wasn't taking full
advantage of my indexes because when I switched the order of my query
from
SELECT l.pid, l.the_geom
FROM landparcels l, landparcels l2
WHERE l2.pid = '1803570000' and (expand(l.the_geom, 1000) && l2.the_geom
AND distance(l.the_geom, l2.the_geom) <= 1000)
to
WHERE l2.pid = '1803570000' and (expand(l2.the_geom, 1000) && l.the_geom
My time went from 609ms to 78ms. The original with_distance didn't
matter the order of the arguments since presumably it wasn't taking
advantage of the gist index.
When I changed my query to
FROM landparcels l , landparcels l2
WHERE l2.pid = '1803570000' and within_distancesql(l2.the_geom,
l.the_geom, 1000)
My time when to 78ms.
For the less optimized
WHERE l2.pid = '1803570000' and within_distancesql(l.the_geom,
l2.the_geom, 1000)
time was 609ms
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, February 09, 2007 6:49 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] within_distance function
Perhaps doing the function as a SQL function rather than a PL/PgSQL
function. Shot in the dark.
P
Obe, Regina wrote:
> On further inspection, I realized my within_distance is not using the
> gist index and that the gain over the just distance check was because
> of the efficiency of extent comparison instead of distance
> comparison.
> I suppose there is no way to trick the optimizer into using an index
> with the function call. Something like a macro of some sort so it
> macro replaces my shorter statement with the more efficient longer
> statement?
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net on behalf of Obe,
> Regina Sent: Fri 2/9/2007 3:32 PM To: PostGIS Users Discussion
> Subject: [postgis-users] within_distance function
> I was hoping to simplify some of my distance queries by creating a
> within_distance function which looks like
> CREATE OR REPLACE FUNCTION within_distance(geom1 geometry, geom2
> geometry, dist double precision) RETURNS boolean AS $BODY$ BEGIN
> return (expand(geom1, dist) && geom2 AND distance(geom1, geom2) <=
> dist) ; END;$BODY$ LANGUAGE 'plpgsql' IMMUTABLE;
> Upon testing this I noticed the following observations
> SELECT l.pid, l.the_geom FROM landparcels l , landparcels l2 WHERE
> l2.pid = '1803570000' and within_distance(l.the_geom, l2.the_geom,
> 1000) ;
> runs in 1610ms and returns 679 rows
> SELECT l.pid, l.the_geom FROM landparcels l, landparcels l2 WHERE
> runs in 609 ms and returns 679 rows
> l2.pid = '1803570000' and (distance(l.the_geom, l2.the_geom) <= 1000)
> runs in 5437 ms and returns 679 rows
> ----- I ran the test a couple of times with similar results. So
> apparently as far as I can tell, my function is probably using my
> gist indexes, but why is it 1/2 the speed of the regular expand call?
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> _______________________________________________ postgis-users mailing
> list postgis-users at postgis.refractions.net
Paul Ramsey
Refractions Research
http://www.refractions.net
pramsey at refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
postgis-users mailing list
