[postgis-users] within_distance function
Paul Ramsey
pramsey at refractions.net
Mon Feb 12 07:31:20 PST 2007
Interesting. I guess the optimizer has an easier time bringing the
SQL function into the plan.
Now, to be "standards compliant" you should rename your function
"DWithin()". Should we include such a thing in the main distro? Seems
a pretty common construction in spatial SQL.
I have often wondered about the wisdom of wrapping the spatial
booleans in appropriate SQL to auto-generate the necessary index
calls. On the one hand it makes life easier and more automagic for
new users. On the other hand, explicitness of intent is lost for
others.
P
On 12-Feb-07, at 5:54 AM, Obe, Regina wrote:
> Great suggestion Paul! My SQL function is running just as fast as the
> expand combination in my code.
> My sql function looks like this
> CREATE OR REPLACE FUNCTION within_distancesql(geom1 geometry, geom2
> geometry, dist double precision)
> RETURNS boolean AS
> $BODY$
> SELECT (expand($1, $3) && $2 AND distance($1, $2) <= $3) ;
> $BODY$
> LANGUAGE 'sql' IMMUTABLE;
> First I realized that I had my queries backward and I wasn't taking
> full
> advantage of my indexes because when I switched the order of my query
> from
> SELECT l.pid, l.the_geom
> FROM landparcels l, landparcels l2
> WHERE l2.pid = '1803570000' and (expand(l.the_geom, 1000) &&
> l2.the_geom
> AND distance(l.the_geom, l2.the_geom) <= 1000)
> to
> WHERE l2.pid = '1803570000' and (expand(l2.the_geom, 1000) &&
> l.the_geom
> My time went from 609ms to 78ms. The original with_distance didn't
> matter the order of the arguments since presumably it wasn't taking
> advantage of the gist index.
> When I changed my query to
> FROM landparcels l , landparcels l2
> WHERE l2.pid = '1803570000' and within_distancesql(l2.the_geom,
> l.the_geom, 1000)
> My time when to 78ms.
> For the less optimized
> WHERE l2.pid = '1803570000' and within_distancesql(l.the_geom,
> l2.the_geom, 1000)
> time was 609ms
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, February 09, 2007 6:49 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] within_distance function
> Perhaps doing the function as a SQL function rather than a PL/PgSQL
> function. Shot in the dark.
> P
> Obe, Regina wrote:
>> On further inspection, I realized my within_distance is not using the
>> gist index and that the gain over the just distance check was because
>> of the efficiency of extent comparison instead of distance
>> comparison.
>> I suppose there is no way to trick the optimizer into using an index
>> with the function call. Something like a macro of some sort so it
>> macro replaces my shorter statement with the more efficient longer
>> statement?
>> ________________________________
>> From: postgis-users-bounces at postgis.refractions.net on behalf of Obe,
>> Regina Sent: Fri 2/9/2007 3:32 PM To: PostGIS Users Discussion
>> Subject: [postgis-users] within_distance function
>> I was hoping to simplify some of my distance queries by creating a
>> within_distance function which looks like
>> CREATE OR REPLACE FUNCTION within_distance(geom1 geometry, geom2
>> geometry, dist double precision) RETURNS boolean AS $BODY$ BEGIN
>> return (expand(geom1, dist) && geom2 AND distance(geom1, geom2) <=
>> dist) ; END;$BODY$ LANGUAGE 'plpgsql' IMMUTABLE;
>> Upon testing this I noticed the following observations
>> SELECT l.pid, l.the_geom FROM landparcels l , landparcels l2 WHERE
>> l2.pid = '1803570000' and within_distance(l.the_geom, l2.the_geom,
>> 1000) ;
>> runs in 1610ms and returns 679 rows
>> SELECT l.pid, l.the_geom FROM landparcels l, landparcels l2 WHERE
>> l2.pid = '1803570000' and (expand(l.the_geom, 1000) && l2.the_geom
>> runs in 609 ms and returns 679 rows
>> l2.pid = '1803570000' and (distance(l.the_geom, l2.the_geom) <= 1000)
>> runs in 5437 ms and returns 679 rows
>> ----- I ran the test a couple of times with similar results. So
>> apparently as far as I can tell, my function is probably using my
>> gist indexes, but why is it 1/2 the speed of the regular expand call?
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer.
>> _______________________________________________ postgis-users mailing
>> list postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> http://www.refractions.net
> Phone: 250-383-3022
> Cell: 250-885-0632
> postgis-users mailing list
