[postgis-users] appending to a LINESTRING
Just van den Broecke
just at justobjects.nl
Mon Feb 12 07:49:16 PST 2007
What is the way to go for appending POINTs to a LINESTRING without
reading the entire LINESTRING into the client ? i.e. for example
SELECT AddPoint(line, GeomFromText('POINT(4.92 52.35)',4326)) as line
FROM ( SELECT line FROM g_track WHERE id=101) foo;
Will do the append but will still require an UPDATE to be done with the
resulting line. Would "one-shot" appending require a (plpg)sql function
or is there some other way ?
thanks,
--Just
http://www.justobjects.nl
The Netherlands
