[postgis-users] appending to a LINESTRING
David William Bitner
david.bitner at gmail.com
Mon Feb 12 08:55:28 PST 2007
Update g_track set line=AddPoint(line, GeomFromText('POINT(4.92 52.35)',4326))
where id=101;
On 2/12/07, Just van den Broecke <just at justobjects.nl> wrote:
> Hi,
> What is the way to go for appending POINTs to a LINESTRING without
> reading the entire LINESTRING into the client ? i.e. for example
> SELECT AddPoint(line, GeomFromText('POINT(4.92 52.35)',4326)) as line
> FROM ( SELECT line FROM g_track WHERE id=101) foo;
> Will do the append but will still require an UPDATE to be done with the
> resulting line. Would "one-shot" appending require a (plpg)sql function
> or is there some other way ?
> thanks,
> --Just
> http://www.justobjects.nl
> The Netherlands
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070212/7a457fff/attachment.html>
