[postgis-users] different results from PGobject.getValue()
Markus Schaber
schabi at logix-tt.com
Tue Feb 13 05:55:55 PST 2007
Hi, Claude,
"Claude Eisenhut" <ce at eisenhutinformatik.ch> wrote:
> Is it expected behaviour that PGobject.getValue() returns different results,
> depending if postgis.jar is on the classpath?
> without postgis.jar PGobject.getValue() returns
> 01010000201555000052B81E85A50E2341B81E85EB3B330F41
> with postgis.jar PGobject.getValue() returns
> SRID=21781;POINT(624466.76 255591.49)
Yes, it is expected.
If you don't have PostGIS installed, then PGObject just memorizes the
data String sent by the server.
When you have PostGIS in your classpath, org.postgis.PGgeometry is
automagically registered, and used for Geometry objects. By default,
getValue() returns the EWKT format which is compatible with PostGIS 0.8
and up. You can manually register org.postgis.PGgeometryLW as handler
class, which returns the hex-Binary form you see above, but only works
with PostGIS 1.X and above.
Regards,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
