[postgis-users] Points or boundaries more efficient for querying?
Guido Lemoine
guido.lemoine at jrc.it
Wed Feb 14 00:31:41 PST 2007
Nick,
If tile boundaries are implicit (i.e. fixed by your choice of tiling grid
and spacing), there is no need to store and or query tile outlines at all.
Have a look at how WorldWind, Google and Virtual Earth do this. VE
is actually VERY cool at this (cooler than GE!). They even provide the
code.
I came across some OSgeo specs on this as well
(http://wiki.osgeo.org/index.php/Tile_Map_Service_Specification)
Thinking about implementing this sometime soon.
GL
Nick Bower wrote:
>Hello.
>We have large quantities of satellite metadata that we will reduce to a
>set of standard tiles covering a large global region of interest. We
>are doing this because storing the data at native resolution will mean
>an enormous amount of irregularly located data to query later.
>We are to spatially query the data; eg give me the tile corresponding to
>my location, and then, give me records for this location corresponding
>to my metadata criteria (ok normally this would be a join on a single
>query I guess).
>So what, is the most efficent way to represent the geometry information
>(the tiles); as centre points or tile boundaries? I initially thought
>points and queries using minimum distance would be least redundant, but
>then the rtree documentation seemed to point to using regions,
>boundaries and contains/intersects type queries would lead to better
>index performance. Is this the case? The tiles will of course be
>regular and adjacent.
>Ta, Nick
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Unit: Support to External Security
Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent the
views of the European Commission
