[postgis-users] problem with proj-4.5.0
Stüwe Rolf
Rolf.Stuewe at stadt.wuppertal.de
Wed Feb 14 02:44:45 PST 2007
I have problems to compile postGIS 1.2.1 under linux with proj-4.5.0 :
I set the variables --with-proj=/.../postgres/proj-4.5.0 and --with-proj-libdir=/.../postgres/proj-4.5.0/src/.libs when compiling. I set the variables USE_PROJ=1 and PROJ_DIR and PROJ_LIBDIR in the file Makefile.config.in, but the error-message is "configure: error: Can't find proj dir.".
At the end of config.log there is an output of all variables and the PROJ_DIR is correct.
Is it wrong to give the "HOME"-directory of proj to the var. PROJ_DIR?
thanks for answere
Rolf
