[postgis-users] problem with proj-4.5.0
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Feb 14 23:56:37 PST 2007
On Wed, 2007-02-14 at 11:44 +0100, Stüwe Rolf wrote:
> Hi,
> I have problems to compile postGIS 1.2.1 under linux with proj-4.5.0 :
> I set the variables --with-proj=/.../postgres/proj-4.5.0   and --with-proj-libdir=/.../postgres/proj-4.5.0/src/.libs when compiling. I set the variables  USE_PROJ=1 and PROJ_DIR and PROJ_LIBDIR in the file Makefile.config.in, but the error-message is "configure: error: Can't find proj dir.".
> At the end of config.log there is an output of all variables and the PROJ_DIR is correct.
> Is it wrong to give the "HOME"-directory of proj to the var. PROJ_DIR?
> thanks for answere
> Rolf
Hi Rolf,
AFAIK --with-proj-libdir is only required if you have a non-standard
installation of proj - try using just the --with-proj variable when
running configure.
HTH,
Mark.
