[postgis-users] Postgis installation: missing pg_config?
Greg Troxel
gdt at ir.bbn.com
Sat Feb 17 06:16:20 PST 2007
I'm on Ubuntu Edgy Eft, have sucessfully built postgresql 8.1, using
pgadmin3 (1.4.3). I'm now trying to install postgis 1.1.7. when i run
configure, the last line says:
checking for pg_config... no
configure: error: PostgreSQL is required by PostGIS
i have postgresql installed and running, but i don't find a pg_config
anywhere in the install directory.
Check that there aren't more PostgreSQL packages. On NetBSD pkgsrc,
pgsql is split into several:
postgresql81-8.1.6 Robust, next generation, object-relational DBMS
postgresql81-client-8.1.6 PostgreSQL database client programs
postgresql81-server-8.1.6 PostgreSQL database server programs
postgresql81-postgis-1.2.1 Spatial database capabilities for PostgreSQL
pg_config is in -client. This seems awkard, since it would be needed
on a machine with only server, but client-only seems like a better
choice, and having a -config package seems silly.
Do you have the 'development' package installed? The server package,
and the server development package?
If the Ubuntu packages don't provide pg_config you should file a bug
report with Ubuntu.
