[postgis-users] how to import SHP into postGIS? error message.
Paul Ramsey
pramsey at refractions.net
Mon Feb 19 11:23:07 PST 2007
Drop your database and start again with a different encoding that
matches the strings in your dbf file.
createdb --encoding=<encoding> dbname
http://www.postgresql.org/docs/8.1/static/multibyte.html
Maciej Skorczewski wrote:
> i use this command:
> ogr2ogr -f postgres "PG:dbname=postgis user=postgres password=pass
> host=localhost port=5432" osienazwy.shp
> this command create a table:
> CREATE TABLE osienazwy
> ogc_fid serial NOT NULL,
> wkb_geometry geometry,
> id double precision,
> idulicy double precision,
> ulica character(30),
> id1 double precision,
> id2 double precision,
> kier2 character(1),
> length numeric(31,15),
> idodcinka double precision,
> CONSTRAINT osienazwy_pk PRIMARY KEY (ogc_fid),
> CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
> CONSTRAINT enforce_geotype_wkb_geometry CHECK
> (geometrytype(wkb_geometry) = 'LINESTRING'::text OR wkb_geometry IS NULL),
> CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
> WITHOUT OIDS;
> ALTER TABLE osienazwy OWNER TO postgres;
> !!!BUT!!!
> i have problem whit encoding so can't load data form shp - have can i
> use another encoding? (i think that table create is ok.)
> i have this error
> http://img89.imageshack.us/img89/3579/errorae0.jpg
> (encoding problem)
> when i use shp2pgsql i get another table (whit this same shp file)
> gid serial NOT NULL,
> id bigint,
> idulicy bigint,
> ulica character varying(30),
> "pełna" character varying(100),
> id1 bigint,
> id2 bigint,
> kier2 boolean,
> length numeric,
> idodcinka bigint,
> the_geom geometry,
> CONSTRAINT osienazwy_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTILINESTRING'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
> WITHOUT OIDS;
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
