[postgis-users] how to import SHP into postGIS? error message.
Maciej Skorczewski
maciej.skorczewski at procad.pl
Mon Feb 19 10:52:23 PST 2007
i use this command:
ogr2ogr -f postgres "PG:dbname=postgis user=postgres password=pass
host=localhost port=5432" osienazwy.shp
this command create a table:
CREATE TABLE osienazwy
ogc_fid serial NOT NULL,
wkb_geometry geometry,
id double precision,
idulicy double precision,
ulica character(30),
id1 double precision,
id2 double precision,
kier2 character(1),
length numeric(31,15),
idodcinka double precision,
CONSTRAINT osienazwy_pk PRIMARY KEY (ogc_fid),
CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
CONSTRAINT enforce_geotype_wkb_geometry CHECK
(geometrytype(wkb_geometry) = 'LINESTRING'::text OR wkb_geometry IS NULL),
CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
WITHOUT OIDS;
ALTER TABLE osienazwy OWNER TO postgres;
!!!BUT!!!
i have problem whit encoding so can't load data form shp - have can i
use another encoding? (i think that table create is ok.)
i have this error
http://img89.imageshack.us/img89/3579/errorae0.jpg
(encoding problem)
when i use shp2pgsql i get another table (whit this same shp file)
gid serial NOT NULL,
id bigint,
idulicy bigint,
ulica character varying(30),
"pełna" character varying(100),
id1 bigint,
id2 bigint,
kier2 boolean,
length numeric,
idodcinka bigint,
the_geom geometry,
CONSTRAINT osienazwy_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTILINESTRING'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
WITHOUT OIDS;
