[postgis-users] help plz
Pedro Doria Meunier
pdoria at netmadeira.com
Mon Feb 19 06:06:15 PST 2007
Hi Lavanya,
You could consider using pgRouting (http://www.postlbs.org/) .
This extension to Postgres/PostGIS needs some topology and topology support
for PostGIS is still in its infancy and barely documented
L
Now to implement topology the *easy* way
Use OpenJump! (http://openjump.org)
Theres a tool there called Planar Graph
You can use it to get every line segment documented (start and end nodes for
each line).
Add a length field to your dataset.
OpenJump also has a tool to calculate areas and lengths
Save your dataset from OpenJump into PostGIS.
The length field acts as an initial cost for turning
Then use the shortest_path() function from pgRouting and youre on your way!
Also heard from the developers of pgRouting that support for turn
restrictions is somewhere in the near future
(OJ Peopleà Im posting this to the list as I think its useful ;-) )
HTH,
Pedro Doria Meunier
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Lavanya
A
Sent: segunda-feira, 19 de Fevereiro de 2007 13:42
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] help plz
Jus need few help from u...im currently using postgres 8.2 and PostGIS
1.2.1..
I have few shapefile, especially roads..which im working on it..
I need to find the route between two points, namely a latitude and longitude
to a place of interest. I thought i should network analysis. But not sure of
what to use and how to achieve my goal.
Can u suggest me wat tool should i use and any special query will do using
postgres? Please i seek ur suggestion
Regards
Lavanya A
_____
Heres a new way to find what you're looking for - Yahoo!
<http://us.rd.yahoo.com/mail/in/yanswers/*http:/in.answers.yahoo.com/>
Answers
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070219/441e1b85/attachment.html>
