[postgis-users] shp2pgsql UTF-8 Encoding Problem
Paul Ramsey
pramsey at refractions.net
Mon Feb 19 13:14:39 PST 2007
The list of encodings is here:
http://www.postgresql.org/docs/8.1/static/multibyte.html
What you want to provide in -W is not the database encoding (that's
already known) but rather the encoding of the strings in your DBF file.
If it's a European language, probably the encoding you want is LATIN1.
Paul
paallen at attglobal.net wrote:
> Hi all,
> I am using Windows XP SP2 (USA English),
> PostgreSQL 8.2 and PostGIS 1.2.0-1
> I have a database with UTF-8 encoding and I am
> trying to import a multipolygon shape file with
> shp2pgsql and it keeps giving me an encoding error
> upon loading it into the database. I know this is
> due to the UNICODE and I found some listings about
> this from 2005 but my encoding skills are weak.
> I have used the shp2pgsql with -w and no better
> luck. I have changed the code page first with
> “chcp 1252” and still no luck. Whenever I use the
> “-W UTF-8” it bombs out because “UTF-8” is not a
> recognized code.
> What are the window's users procedures to import
> an plan-jane US ASCII shape file into an UTF-8
> database. I am interested in passing this stage
> so I can experiment with the latest ZigGIS release!
> Thanks a lot.
> Phillip J. Allen
> Consulting Geochemist
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
