[postgis-users] joining "nearest" data
Kirk Wythers
kwythers at umn.edu
Tue Feb 20 05:47:57 PST 2007
On Feb 20, 2007, at 6:46 AM, Obe, Regina wrote:
> Hi Kirk,
> I meant substitute all references to ref_solar_station_id with
> ref_weather_station_id.
> The idea is to update the ref_weather_station_id of those that
> don't have any weather for that year with those that do. Basically
> the first step sets the ref_weather_station_id to the station_id
> if the station has weather data for that year and null if it does
> not and similarly ref_sol with station_id if the station has solar
> data for that year. So by the time you get to step 5 those that
> have nulls in ref_weather_station_id have no weather for that year.
> Those that have weather for that year (assuming I wrote the query
> right - the ref_weather_station_id should be the same as the
> station_id) . Hope my explanation isn't even more confusing.
Not at all Regina. Thanks for all your assistance. I actually took a
guess that you meant exactly that. I got your new table and the final
query working and then had to give my attention to other projects. I
will pick back up this week. I think one issue I have to playing with
the 30 km boundary you set. I tired changing that to 50 km, and 100
km, and 200 km just to see how many stations get picked up with the
more flexible rule. Now that I have the filled after a 200 km INSERT,
I think I need to delete all rows and start again with a more rigid
rule (say 20 - 30 km).
Also, I think I'll add a 'longname' field for both the
ref_weather_station_id and the ref_solar_station_id, so that a human
can more immediately understand which stations are being lumped
together.
Thanks again,
Kirk
> Thanks,
> Regina
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Kirk Wythers
> Sent: Friday, February 16, 2007 4:53 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] joining "nearest" data
> On Feb 15, 2007, at 7:35 AM, Obe, Regina wrote:
>> Step 5 - Do the same as Step 4 except for ref_weather_station_id
> Do you mean substitute ref_weather_station_id for
> ref_solar_station_id in line one only. Bottom line, are you saying
> that you want to fill in in ref_weather_station_id with those that
> have no solar data for that year, or with those that have no
> weather data for that year?
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070220/3b3cfeb0/attachment.html>
