[postgis-users] Sudden failure in client connection
myunghwa Hwang
mhwang4 at uiuc.edu
Thu Feb 22 14:14:56 PST 2007
Hello, List!
I have beening using Postgresql 8.13 with Postgis1.1.2 on Mac OS X
Server.
And I'm not good at db administration.
To use Postgresql db for GATE, a text mining tool,
I changed some setting of postgresql.conf two weeks ago.
Before all settings were defaults, and client connection had no problem.
What changed in postgresql.conf is the size of shared_buffers and
work_mem.
I increased their sizes, but forgot to reload the changed settings a
lot.
Just after the change, there was no problem, since I guess I didn't
reload the settings.
Soon I needed to reboot the OS because of some software and system
upgrades from Apple.
I guess when rebooting the server postgres crashed because of the
changed setting.
I couldn't connect to db server, so I restarted the postgres by using
pg_ctl.
Then it showed the setting were wrong, I recovered all settings to
the previous values.
And restarting worked, so I could connect db locally.
But client connection is not working. I didn't change anything
related to TCP/IP connection.
Port 5432 was manually added, and in postgresql.conf I explicitly set
to allow the server to listen all connections through 5432 port.
Of course, I reloaded all the settings again,
but still client connection is not working.
So, I decided to move into new version of PostgreSQL and PostGIS, and
dumped the whole db.
But I want to know why this happens.
Anybody has some ideas about this trouble?
from Myunghwa Hwang
