[postgis-users] Sudden failure in client connection
Paul Ramsey pramsey at refractions.net
Thu Feb 22 14:26:19 PST 2007
myunghwa Hwang wrote:
> Just after the change,
> there was no problem, since I guess I didn't reload the settings.
> Soon I needed to reboot the OS because of some software and system
> upgrades from Apple. I guess when rebooting the server postgres
> crashed because of the changed setting.
In did not crash, it was unable to start, because you asked it to
allocation more shared buffers than your operating system would allow.
The right fix is to increase the shared buffers in OS/X so your postgres
can run. That way you can reap the performance benefit of properly sized
buffers.
As far as your other problem, almost certainly there is something else
you changed that you forgot to change back, which you just cannot
recall.  Installing a completely fresh replacement has the salutary
effect of wiping out all your edits, both well- and ill- considered.
P
I couldn't connect to db
> server, so I restarted the postgres by using pg_ctl. Then it showed
> the setting were wrong, I recovered all settings to the previous
> values. And restarting worked, so I could connect db locally. But
> client connection is not working. I didn't change anything related to
> TCP/IP connection. Port 5432 was manually added, and in
> postgresql.conf I explicitly set to allow the server to listen all
> connections through 5432 port. Of course, I reloaded all the settings
> again, but still client connection is not working. So, I decided to
> move into new version of PostgreSQL and PostGIS, and dumped the whole
> db. But I want to know why this happens. Anybody has some ideas about
> this trouble?
> from Myunghwa Hwang _______________________________________________
> postgis-users mailing list postgis-users at postgis.refractions.net
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
