[postgis-users] Boundary() without the internal holes?
Brad Ediger brad at bradediger.com
Wed Feb 28 15:57:12 PST 2007
Sounds like you're looking for ExteriorRing(polygon). A polygon has
one exterior ring and zero or more interior rings. ExteriorRing is a
lot cheaper (computationally) than calculating a convex hull or
boundary.
Documentation here -> http://postgis.refractions.net/docs/ch06.html
Brad
On Feb 28, 2007, at 5:30 PM, John Carnes wrote:
> I am trying to figure out how to get a polygon that is the boundary
> of a geounion of polygons without getting polygons for the internal
> holes.
> The boundary() function is close, but includes the internal holes.
>     SELECT boundary(geomunion(p.the_geom)) FROM parcels AS p WHERE
> p.neighborhood=5;
> A convex hull, leaves out the internal holes, but the resulting
> polygon doesn't touch the actual boundary anywhere that it is concave.
> Thanks in advance for your ideas on how to do this.
> I'd really like to avoid having to delete the internal hole
> polygons by hand, which is my current solution.
> John Carnes
> MapTools
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070228/f52f1eea/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070228/f52f1eea/attachment.bin>
