[postgis-users] SpatialEJB3: (PostGIS and Hibernate)
David Potts dave.potts at pinan.co.uk
Mon Jan 8 02:02:01 PST 2007
Hi
Which "version" of the postgres database driver are you going to use ?
This might be a red herring!
But several months ago I was going to implement a trigger function using
postgres/j( an jvm within the database), since I also wanted to use
postgis in the same application,  I was told that the both products used
different versions of the java jdbc driver.
I abandon the idea.  IF there is a compatbility issue, it might be worth
sorting it out, now before are large amount of hard work is done.
Dave.
> Hi Markus,
> Andrew solved this problem, I sent him the postgis binaries off list and
> this fixed the error.
> I know the jars are built with a makefile at the moment, is it possible
> to use an ant script for future releases, (I can provide a simple one),
> it would perhaps solve some of these issues.
> I am having a go at writing the hibernate dialect for postgis so you can
> do spatial hql, ejb-ql if anyone has already done this let me know!
> Thanks,
> Norman
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Markus Schaber
> Sent: 08 January 2007 08:59
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] SpatialEJB3: (PostGIS and Hibernate)
> Hi, Andrew,
> Andrew Hughes <azza at lisasoft.com> wrote:
>> 13:14:56,183 ERROR [JDBCExceptionReporter] ERROR: parse error -
> invalid geometry
> AFAICS, that's the hint what's going wrong.
> Can you use extended server-side logging, or tcpdump or such, to tell
> us what the server is really seeing?
> Regards,
> Markus
> Markus Schaber | Logical Tracking&Tracing International AG
> Dipl. Inf.     | Software Development GIS
> Fight against software patents in Europe! www.ffii.org
> www.nosoftwarepatents.org
> postgis-users mailing list
