[postgis-users] AsKML function
Guido Lemoine
guido.lemoine at jrc.it
Tue Jan 9 02:54:45 PST 2007
Thanks, Thomas. I'll have a look. Luckily, I can understand your
bad German as well ;-)
GL
Thomas Zuberbuehler wrote:
> Hi Guido
> Have a look at http://www.zubi.li/wiki/doku.php?id=prog:java (text
> german)
> I written a SimpleKMLExporter in Java that generate a KML file from a
> WKT string. The javadoc is unfortunately written in my bad english.
> Regards,
> Thomas
> 2007/1/9, Guido Lemoine <guido.lemoine at jrc.it>:
>> I checked the postgis 1.2.0 source, but there is not really an asKML()
>> function
>> at all. It just seemed to have slipped into the manual. Is there
>> anything ongoing?
>> I guess it would be fairly straightforward to derive asKML from the
>> asGML
>> equivalent (or do some XSLT transform on asGML output externally).
>> NB. context is that I'd like to generate dynamic KML from postgis to
>> include
>> into Google Earth via JSP requests.
>> GL
>> Guido Lemoine wrote:
>> > I just saw that an asKML() function was added to the on-line postgis
>> > manual (1.2.0).
>> > In the release notes, there is no trace to when this was added.
>> > Apparently not in 1.1.5. Does it require an upgrade to 1.2.0
>> (preferably
>> > soft, but how?).
>> > GL
>> > TECHER David wrote:
>> >> Hi
>> >> I saw the link
>> >> http://postgis.refractions.net/support/wiki/index.php?WishList
>> >> AsKML seems to be a great function in the future
>> >> The code to do that seems to be like the code used for ASSVG()...
>> >> The only question I ask myself is "Is the projection SRID fixed
>> for 4326
>> >> <----> WGS84 GPS???"
>> >> In the code of ASKML should be the srid to be fixed to 4326?
>> >> Sorry for my bad English.
>> >> Any idea?
>> >> Thanks for any reply
>> ___________________________________________________________________________
>> >> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et
>> >> son interface révolutionnaire.
>> >> http://fr.mail.yahoo.com
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Joint Research Centre, European Commission
>> Institute for the Protection and Security of the Citizen (IPSC)
>> Unit: Support to External Security
>> Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
>> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
>> WWW: http://ses.jrc.it
>> Disclaimer:
>> Views expressed are those of the individual and do not represent the
>> views of the European Commission
Disclaimer:
