[postgis-users] AsKML function
Thomas Zuberbuehler
tzuberbuehler at datacomm.ch
Tue Jan 9 02:00:07 PST 2007
Hi Guido
Have a look at http://www.zubi.li/wiki/doku.php?id=prog:java (text german)
I written a SimpleKMLExporter in Java that generate a KML file from a
WKT string. The javadoc is unfortunately written in my bad english.
Regards,
Thomas
2007/1/9, Guido Lemoine <guido.lemoine at jrc.it>:
> I checked the postgis 1.2.0 source, but there is not really an asKML()
> function
> at all. It just seemed to have slipped into the manual. Is there
> anything ongoing?
> I guess it would be fairly straightforward to derive asKML from the asGML
> equivalent (or do some XSLT transform on asGML output externally).
> NB. context is that I'd like to generate dynamic KML from postgis to include
> into Google Earth via JSP requests.
> GL
> Guido Lemoine wrote:
> > I just saw that an asKML() function was added to the on-line postgis
> > manual (1.2.0).
> > In the release notes, there is no trace to when this was added.
> > Apparently not in 1.1.5. Does it require an upgrade to 1.2.0 (preferably
> > soft, but how?).
> > GL
> > TECHER David wrote:
> >> Hi
> >> I saw the link
> >> http://postgis.refractions.net/support/wiki/index.php?WishList
> >> AsKML seems to be a great function in the future
> >> The code to do that seems to be like the code used for ASSVG()...
> >> The only question I ask myself is "Is the projection SRID fixed for 4326
> >> <----> WGS84 GPS???"
> >> In the code of ASKML should be the srid to be fixed to 4326?
> >> Sorry for my bad English.
> >> Any idea?
> >> Thanks for any reply
> >> ___________________________________________________________________________
> >> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et
> >> son interface révolutionnaire.
> >> http://fr.mail.yahoo.com
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Joint Research Centre, European Commission
> Institute for the Protection and Security of the Citizen (IPSC)
> Unit: Support to External Security
> Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
> WWW: http://ses.jrc.it
> Disclaimer:
> Views expressed are those of the individual and do not represent the
> views of the European Commission
Thomas Zuberbuehler
http://www.zubi.li
