[postgis-users] Transferring ArcSDE tables to PostGIS using FME
Paul Ramsey
pramsey at refractions.net
Mon Jan 15 18:00:37 PST 2007
If "several" tables are in the millions of records, then it could
take some hours, probably not all night though. Transferring with
FME is not as fast as some of the bulk-loading strategies available.
A popular trick is to attach some triggers to the source tables to
that they generate deltas as they are updated, then only transfer the
deltas nightly.
On 15-Jan-07, at 12:18 PM, Brian Timoney wrote:
> I'm looking for information from those who have had experience
> routinely copying ArcSDE tables to PostGIS using FME. Specifically
> I have a client mulling the feasibility of batch scheduling a
> transfer of tables on a nightly basis. While I've been told that's
> a fairly straightforward process, some of the tables are large-ish
> (e.g. a point file with 2 million records) and I don't have any
> idea whether the transfer time would be in the minutes, tens of
> minutes, or hours. Of course I understand much of it depends on
> hardware specs, but having a general sense of what orders of
> magnitude we're talking would be helpful.
> Thanks,
> Brian
> postgis-users mailing list
