[postgis-users] "Field xx renamed to XX_01"
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Mon Jan 22 00:07:29 PST 2007
Yes, I dumped other tables and that was ok. It seems there are only a
couple of tables out of the 500 or so we have that does it... I
couldn't figure out any pattern...
> Have you tried dumping out another table and does it do the same
> thing?
>>> But the problem remains: My dbf file shows, for example, the column
>>> "id" and another "id_01". So all columns are doubled and an "_01"
>>> added to the column name...
>>> Stef
>> Hi Stefan,
>> Unfortunately there is not enough information here for us to find out
>> what is happening. For example, which version of PostGIS/PostgreSQL
>> are you using? (SELECT version() / SELECT postgis_full_version() ).
>> Also you'd need to supply a .sql file containing the definitions for
>> your table along with 3-4 sample geometries, plus with the resulting
>> DBF file that is produced.
> Hi,
> here is the command I use to export the table2shapefile:
> 	pgsql2shp -k -f glaciers my_database glaciers
> ______________________________________________________________________
> __
> _________________
> Here are the dbf titels (with one exempl. entry):
> 	id   name   country_id   lat   long   id_01   name_01
> country_01
> lat_01   long_01
> 	1037   Austre Broggerbreen   852   78.8830000000   11.8330000000
> __
> _________________
> PostGIS version:
> 	PostgreSQL 8.1.2 on powerpc-apple-darwin8.4.0, compiled by GCC
> powerpc-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc.
> build 5247)
> 	POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STAT
> __
> _________________
> And here is the SQL file for the table:
> SET SESSION AUTHORIZATION 'ss_admin';
> SET search_path = "public", pg_catalog;
> -- Definition
> -- DROP TABLE "public"."glaciers";
> CREATE TABLE "glaciers" (
>      "id" integer NOT NULL,
>      "name" character varying(23),
>      "country_id" integer,
>      "lat" double precision,
>      "long" double precision,
>      "the_geom" geometry,
>      CONSTRAINT "glaciers_pkey" PRIMARY KEY (id)
> ) WITH OIDS;
> COPY "glaciers" FROM stdin;
> 1037	Austre Broggerbreen	852	78.882999999999996	11.833
> 00000000014027AA7EF9DB22D14053B883126E978D
> 1050	Cares\\303\\250r	444	46.5	10.667
> 0000000001402555810624DD2F4047400000000000
> 1055	Djankuat	748	43.200000000000003
> 42.767000000000003
> 00000000014045622D0E560419404599999999999A
> 1035	Enchaurren Norte	180	-33.582999999999998
> -70.132999999999996
> 0000000001C0518883126E978DC040CA9FBE76C8B4
> 1039	Engabreen	672	66.650000000000006	13.85
> 0000000001402BB333333333334050A9999999999A
> 1049	Gries	864	46.5	8.3000000000000007
> 0000000001402099999999999A4047400000000000
> 1043	Gr\\303\\245subreen	672	61.649999999999999
> 8.5999999999999996
> 00000000014021333333333333404ED33333333333
> 1031	Gulkana	944	63.267000000000003	-145.417
> 0000000001C0622D5810624DD3404FA22D0E560419
> 1045	Hardangerjokulen	672	60.533000000000001	7.367
> 0000000001401D77CED916872B404E44395810624E
> 1041	Hellstugubreen	672	61.566000000000003
> 8.4329999999999998
> 00000000014020DDB22D0E5604404EC872B020C49C
> 1052	Hintereisferner	56	47.082999999999998	10.917
> 00000000014025D5810624DD2F40478A9FBE76C8B4
> 1053	Kesselwandferner	56	46.829999999999998
> 10.800000000000001
> 0000000001402599999999999A40476A3D70A3D70A
> 1060	Leviy Aktru	748	50.082999999999998
> 87.683000000000007
> 00000000014055EBB645A1CAC140490A9FBE76C8B4
> 1059	Maliy Aktru	748	50.082999999999998	87.75
> 00000000014055F0000000000040490A9FBE76C8B4
> 1036	Midre Lov\\303\\251nbreen	852	78.882999999999996
> 12.067
> 00000000014028224DD2F1A9FC4053B883126E978D
> 1044	Nigardsbreen	672	61.716999999999999	7.133
> 0000000001401C883126E978D5404EDBC6A7EF9DB2
> 1058	No. 125 (Vodopadniy)	748	50.100000000000001
> 87.700000000000003
> 00000000014055ECCCCCCCCCCD40490CCCCCCCCCCD
> 1033	Place	160	50.433	-122.59999999999999
> 0000000001C05EA666666666664049376C8B439581
> 1048	Sarennes	304	45.109999999999999
> 6.1660000000000004
> 00000000014018A9FBE76C8B4440468E147AE147AE
> 1046	Silvretta	864	46.832999999999998	10.08
> 0000000001402428F5C28F5C2940476A9FBE76C8B4
> 1051	Sonnblickkees	56	47.049999999999997
> 12.949999999999999
> 00000000014029E666666666664047866666666666
> 1034	South Cascade	944	48.350000000000001	-121.05
> 0000000001C05E43333333333340482CCCCCCCCCCD
> 1047	St. Sorlin	304	45.183	6.1660000000000004
> 00000000014018A9FBE76C8B444046976C8B439581
> 1040	Storbreen	672	61.566000000000003
> 8.1329999999999991
> 0000000001402044189374BC6A404EC872B020C49C
> 1038	Storglaci\\303\\244ren	860	67.900000000000006	18.567
> 000000000140329126E978D4FE4050F9999999999A
> 1056	Tsentralniy Tuyuksuyski	476	43.049999999999997
> 77.082999999999998	00000000014053454FDF3B645A4045866666666666
> 1057	Urumqihe S. No. 1	184	43.082999999999998
> 86.816999999999993
> 00000000014055B449BA5E353F40458A9FBE76C8B4
> 1054	Vernagtferner	56	46.883000000000003	10.817
> 00000000014025A24DD2F1A9FC4047710624DD2F1B
> 1032	Wolverine	944	60.399999999999999	-148.917
> 0000000001C0629D5810624DD3404E333333333333
> 1042	\\303\\205lfotbreen	672	61.75	5.6500000000000004
> 0000000001401699999999999A404EE00000000000
> -- Indexes
> CREATE UNIQUE INDEX glaciers_pkey ON glaciers USING btree (id);
> CREATE INDEX glaciers_the_geom_gist ON glaciers USING gist (the_geom);
> __
> _________________
> Hope this helps to identify the problem.
> Thanks for your precious help!
> Stef
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally
> privileged and/or exempt from disclosure pursuant to Massachusetts
> law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and
> delete the material from any computer.
