AW: [postgis-users] Multipolygon an shape
Stüwe Rolf
Rolf.Stuewe at stadt.wuppertal.de
Thu Jan 25 01:42:21 PST 2007
> Hallo,
> I have a problem with a polygon:
> I want to create a shape-File from a geometry, which is a multipolygon
> by definition with the statement:
> pgsql2shp -f abc verdis_beta wsw_shp
> and get the following error message:
> ERROR: Cannot have multiple geometry types in a shapefile.
> Use option -t(unimplemented currently,sorry...) to specify what type
> of geometry you want dumped
It seems your table contains several geometry types (POLYGON, MULTIPOLYGON, others ?).
A shapefile must store the same object types,
try a query like:
select distinct geometryType(the_geom) from verdis_beta;
to see the table objects types.
You may need to run multi(the_geom) to force multi objects if you have mixed polygons and multipolygones
> And another question:
> I think that I perhaps have overlapping geometrys in my table and they
> can not build a shapefile.
> When I tryed to take the function "overlaps" to test my table (with
> 600,000
> polygons) , the duration is very long, even on a small part of my data.
> How can I accelerate the overlaps-function ?
Overlapping geometries can be stored in a shapefile !
Are you using the && operator in your overlaps query ?
Nicolas
Hello Nicolas,
thank you for the 1st answere, you are wright, I have Polygons AND Multipolygons in the data.
But the 2nd answere I don't understand. I don't use the && operator. Will this be better for the performance?
Rolf
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
