[postgis-users] Nearest point between a given point and a multilinestring
Paul Ramsey
pramsey at refractions.net
Tue Jan 30 08:48:06 PST 2007
There is not such a function right now, add it to the
http://postgis.refractions.net/support/wiki/index.php?WishList or submit
an implementation.
As an aside, you will not be getting the true distance between the
features, just an approximation, since the nearest point in the 2D
cartesian interpretation of lat/lon is not the actual nearest point.
And since you're getting an approximation anyways, you could roll your
own approximation, by taking the "distance" in degrees and multiplying
it by a meters per degree measurement you synthetically construct in the
local area. (Take the distance between the centroids of your objects,
for example.)
Something like:
distance(a,b) * distance_sphere(centroid(a), centroid(b)) /
distance(centroid(a), centroid(b))
Eric FRANCOIS wrote:
> I'm able to find the nearest multiline string from a given point with this
> query:
> select distance(s.the_geom, SetSRID(MakePoint(3.23,48.2), 4326)) as dist
> from streets_db as s
> WHERE s.the_geom && expand(SetSRID(MakePoint(3.23,48.2), 4326),0.01) AND
> distance(s.the_geom, SetSRID(MakePoint(3.23,48.2), 4326)) <= 0.01
> order by dist asc limit 1
> But how can I find the X-Y coordinate of the nearest point on this
> MULTILINESTRING to perform a
> distance_sphere(the_given_point,the_finding_nearest_point_on_the_multilinest
> ring)?
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
