[postgis-users] SpatialEJB3: (PostGIS and Hibernate)
Norman Barker
nbarker at ittvis.com
Tue Jan 30 08:54:58 PST 2007
Hi Markus,
Here is an ANT script to help you on your way :-) It is a simple
script, the only trick is excludes="org/postgresql/*" when building the
postgis.jar.
Dropping build.xml in postgis.xxx/java, and creating a subfolder called
lib containing the postgres driver jar files, then running 'ant' will
create the postgis jar file in the dist folder.
It is relatively easy to add the other source projects to the build file
by editing src.dir etc.
Norman
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Markus Schaber
Sent: 29 January 2007 13:51
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] SpatialEJB3: (PostGIS and Hibernate)
Hi, Norman,
"Norman Barker" <nbarker at ittvis.com> wrote:
> I know the jars are built with a makefile at the moment, is it
possible
> to use an ant script for future releases, (I can provide a simple
one),
> it would perhaps solve some of these issues.
I was thinking about using ant instead of make several times now, but
abandoned it for the sake of binary package creators.
However, the pain caused by make is growing, and so it's likely that
the build will be changed to ant eventually.
Regards,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/xml
Desc: build.xml
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070130/a13190e5/attachment.xml>
