[postgis-users] Error installing PostGis
postgreadm at ibge.gov.br postgreadm at ibge.gov.br
Mon Jul 2 06:13:57 PDT 2007
Finally we've installed postigs with geos and proj, the aditional steps
above were necessary before ./configure of proj:
cd /root/proj-4.5.0
grep ?r 'fpic' *
vi configure
:1,20000 s/fpic/fPIC/g -> replace fpic by fPIC
Administracao Postgre
11/05/2007 11:13
        Para:   PostGIS Users Discussion <postgis-users at postgis.refractions.net>
        cc:
        Assunto:        Re: [postgis-users] Error installing PostGis
Hi everybody, I'm still looking for help !!!
Since then I've found this explanation in an IBM's manual (http://www-306.ibm.com/software/htp/tpf/pages/gtpm1mst.pdf):
Relocation error Problem: I received error message relocation truncated to fit :.
Solution: This is actually a binutils error, but the error occurs when you make a
call to tpf-gcc and specify the -shared command or the -or command, or
both, to tell the compiler to make a call to the linker. This error is caused when your global offset table (GOT) size has exceeded
512 entries. When the GOT has reached this size, you must use the -fPIC option instead of the -fpic option when compiling your code. You must add the -fPIC option to the
makefile for your library in all the correct areas because all source code
in the shared object must have this option. You can mix and match the
-fpic and -fPIC when your GOT contains fewer than 512 entries is allowed. However, you cannot mix and match these options when the GOT has 512
entries or more.
It seems that make is using both options but I've found only the string "-fPIC" in files of /postgresql-8.1.4/contrib/postgis-1.0.6 directory (using grep
command).
Could the option -fpic be a default value of a gcc parameter? How can I check or clear the
content of  "global offset table"?
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 # make
make -C lwgeom
make[1]: Entering directory
`/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom'
sh ../geos_version.sh /usr/local > postgis_geos_version.h
gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -Wendif-labels
-fno-strict-aliasing -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.0.6"'
-DPOSTGIS_SCRIPTS_VERSION='"0.3.0"' -DPOSTGIS_BUILD_DATE='"2007-04-18
15:21:16"' -I/usr/local/include -DUSE_PROJ  -I/usr/local/include
-DAUTOCACHE_BBOX=1  -g -O2 -fPIC -fexceptions -DUSE_GEOS -DUSE_STATS -fpic -shared -Wl,-soname,liblwgeom.so.1  measures.o box2d.o ptarray.o
lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o
lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o  wktunparse.o lwgparse.o
wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o
lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o
lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o
lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o
lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o
lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o
-L/root/postgresql-8.1.4/contrib/postgis-1.0.6/../../src/port
-L/usr/local/lib -L/usr/local/lib
-L/root/postgresql-8.1.4/contrib/postgis-1.0.6/../../src/port -lstdc++
-lgeos -lproj -Wl,-rpath,/usr/local/pgsql/lib -o liblwgeom.so.1.0
measures.o(.text+0xbd8): In function `pt_in_ring_2d':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/measures.c:28: relocation truncated to fit: R_390_GOT12 lwerror
ptarray.o(.text+0x572): In function `ptarray_addPoint':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/ptarray.c:289: relocation truncated to fit: R_390_GOT12 lwerror
ptarray.o(.text+0x592):/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/ptarray.c:296:
lwgeom_api.o(.text+0x25e): In function `box3d_to_box2df_p':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:192: relocation truncated to fit: R_390_GOT12 lwnotice
lwgeom_api.o(.text+0x3da): In function `getPoint_internal':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:667: relocation truncated to fit: R_390_GOT12 lwerror
lwgeom_api.o(.text+0x554): In function `lwgeom_getsubgeometry_inspected':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1071: relocation truncated to fit: R_390_GOT12 lwerror
lwgeom_api.o(.text+0x5f2): In function `printBOX3D':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1590: relocation truncated to fit: R_390_GOT12 lwnotice
lwgeom_api.o(.text+0x674): In function `printType':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1685: relocation truncated to fit: R_390_GOT12 lwnotice
lwgeom_api.o(.text+0xa26): In function `printBYTES':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1635: relocation truncated to fit: R_390_GOT12 lwnotice
lwgeom_api.o(.text+0xa8e):/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1641:
lwgeom_api.o(.text+0xac2): In function `parse_lwgeom_wkt':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:2167:
additional relocation overflows omitted from the output
collect2: ld returned 1 exit status
make[1]: *** [liblwgeom.so.1.0] Error 1
make[1]: Leaving directory
make: *** [liblwgeom] Error 2
Enviado Por: postgis-users-bounces at postgis.refractions.net
18/04/2007 17:29
Favor responder a PostGIS Users Discussion
        Para:   postgis-users at postgis.refractions.net
        cc:     vivacqua at ibge.gov.br, versant at ibge.gov.br
        Assunto:        [postgis-users] Error installing PostGis
I'm trying to install PostGis with GEOS and PROJ and I'm getting this
error when running make
We are using the following software versions:
z/Linux: SUSE Entreprise Edition SLES9 SP3
GEOS 2.1.4
Proj 4.5.0
PostGis 1.0.6
PostgreSQL 8.1.4
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 # make -v
GNU Make 3.80
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 # gcc -v
Reading specs from /usr/lib64/gcc-lib/s390x-suse-linux/3.3.3/specs
Configured with: ../configure --enable-threads=posix --prefix=/usr
--with-local-prefix=/usr/local --infodir=/usr/share/info
--mandir=/usr/share/man --enable-languages=c,c++,f77,objc,java,ada
--disable-checking --libdir=/usr/lib64 --enable-libgcj
--with-gxx-include-dir=/usr/include/g++ --with-slibdir=/lib64
--with-system-zlib --enable-shared --enable-__cxa_atexit s390x-suse-linux
Thread model: posix
gcc version 3.3.3 (SuSE Linux)
Any clue?
Thanks in advance.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070702/a4a93e72/attachment.html>
