[postgis-users] Large geometry issue
Gregory Williamson
Gregory.Williamson at digitalglobe.com
Thu Jul 5 05:06:13 PDT 2007
FWIW, this is PostgreSQL 8.2.4, POSTGIS="1.2.1" GEOS="3.0.0rc4-CAPI-1.3.3" USE_STATS
on a linux box with 8 gigs o' RAM ...
GSW
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Gregory Williamson
Sent: Thu 7/5/2007 3:09 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Large geometry issue
Dear peoples,
I have a problem with a query that uses an absurdly large geometry (2530 in a single polygon). This is srid -1 (part of a large test of postgres vs some other database product). Everything has been vacuumed and analyzed.
The initial search to find candidates in a target table is quite fast:
catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE x.bbox && w.geometry AND x.id_as_int = 114672;
count
13168
(1 row)
Time: 9.472 ms
Trying to get the list narrowed to geometries that are completely contained by the requested shape is slow:
catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE x.bbox && w.geometry AND distance(x.geometry,w.geometry) = 0 and x.id_as_int = 114672;
count
1112
(1 row)
Time: 69277.780 ms
So I have two questions:
a) anything better to use than "distance(x,y) = 0) ? I tried st_within -- it is about the same speed but returns no polys, which is strange to me, but I also haven't looked at these in detail yet. For example:
catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE x.bbox && w.geometry AND st_within(x.geometry,w.geometry) and x.id_as_int = 114672;
count
0
(1 row)
Time: 1173.185 ms
(same results with st_within(w.geometry,x.geometry):
catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE x.bbox && w.geometry AND st_within(w.geometry,x.geometry) and x.id_as_int = 114672;
count
0
(1 row)
b) anything I can do to speed things up ? I have tried boosting work mem to 16 megs (from 1) and it made no apparent difference.
I have a self contained test case that shows the same behavior -- the one large poly and all the candidates in another table. Apologies for the size; hopefully it's not been mangled in the transfers.
Explain analyze of the sample (the sequential is sensible since there is only one row in the table):
catest=# explain analyze select count(*) from wsc_candidates w, oli_req x WHERE w.geometry && x.bbox AND distance(w.geometry,x.oli_req_geom) > 0 AND x.oli_req_id = 114672;
QUERY PLAN
Aggregate (cost=20.28..20.29 rows=1 width=0) (actual time=77232.858..77232.859 rows=1 loops=1)
-> Nested Loop (cost=0.00..9.30 rows=4389 width=0) (actual time=6.389..77221.506 rows=12056 loops=1)
Join Filter: (distance(w.geometry, x.oli_req_geom) > 0::double precision)
-> Seq Scan on oli_req x (cost=0.00..1.01 rows=1 width=40602) (actual time=0.007..0.009 rows=1 loops=1)
Filter: (oli_req_id = 114672)
-> Index Scan using wsc_c_spatial_ndx on wsc_candidates w (cost=0.00..8.27 rows=1 width=109) (actual time=0.022..25.991 rows=13168 loops=1)
Index Cond: (w.geometry && x.bbox)
Filter: (w.geometry && x.bbox)
Total runtime: 77232.901 ms
(9 rows)
Time: 77233.773 ms
And for the real thing:
catest=# explain analyze select count(*) from wtm_sub_cell w, order_line_item x WHERE w.geometry && x.bbox AND distance(w.geometry,x.geometry) = 0 AND x.id_as_int = 114672;
QUERY PLAN
Aggregate (cost=141.83..141.84 rows=1 width=0) (actual time=77457.587..77457.588 rows=1 loops=1)
-> Nested Loop (cost=5.99..141.83 rows=1 width=0) (actual time=15.682..77456.541 rows=1112 loops=1)
Join Filter: (distance(w.geometry, x.geometry) = 0::double precision)
-> Index Scan using oli_id_ndx on order_line_item x (cost=0.00..8.30 rows=1 width=383) (actual time=0.012..0.018 rows=1 loops=1)
Index Cond: (id_as_int = 114672)
-> Bitmap Heap Scan on wtm_sub_cell w (cost=5.99..132.97 rows=32 width=109) (actual time=2.988..21.796 rows=13168 loops=1)
-> Bitmap Index Scan on wsc_geom_idx1 (cost=0.00..5.98 rows=32 width=0) (actual time=2.828..2.828 rows=13168 loops=1)
Total runtime: 77457.633 ms
(10 rows)
Time: 77458.458 ms
The tables involved by size:
catest=# select count(*) from wsc_candidates;
count
13168
(1 row)
Time: 2.586 ms
catest=# select count(*) from oli_req;
count
1
(1 row)
Time: 0.193 ms
catest=# select count(*) from wtm_sub_cell;
count
6399928
(1 row)
Time: 1776.508 ms
catest=# select count(*) from order_line_item;
count
395921
(1 row)
Time: 176.083 ms
Many thanks for your time and bandwidth!
Greg Williamson
Senior DBA
GlobeXplorer LLC, a DigitalGlobe company
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information and must be protected in accordance with those provisions. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
(My corporate masters made me say this.)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070705/0ad1f602/attachment.html>
