[postgis-users] Large geometry issue
Martin Davis mbdavis at refractions.net
Thu Jul 5 16:09:04 PDT 2007
Greg,
Can you elaborate on your statement "2530 in a sinlge polygon"?  Do you
mean holes or subPolygons in a MultiPolygon?
Either way, currently JTS is not optimized for working with very large
numbers of holes and sub-polygons.  As Paul says, we are currently
working on improving this.  Hopefully we can at least match the
performance of the Other DMBS(es) for this situation!
Would it be possible for me to obtain this geometry for testing?
Martin
Gregory Williamson wrote:
> Dear peoples,
> I have a problem with a query that uses an absurdly large geometry
> (2530 in a single polygon). This is srid -1 (part of a large test of
> postgres vs some other database product). Everything has been vacuumed
> and analyzed.
> The initial search to find candidates in a target table is quite fast:
> catest=# select count(*) from wtm_sub_cell w, order_line_item x WHERE
> x.bbox && w.geometry AND x.id_as_int = 114672;
>  count
>  13168
> (1 row)
> Time: 9.472 ms
> Trying to get the list narrowed to geometries that are completely
> contained by the requested shape is slow:
> x.bbox && w.geometry AND distance(x.geometry,w.geometry) = 0 and
>  count
>   1112
> (1 row)
> Time: 69277.780 ms
> So I have two questions:
>   a) anything better to use than "distance(x,y) = 0) ? I tried
> st_within -- it is about the same speed but returns no polys, which is
> strange to me, but I also haven't looked at these in detail yet. For
> example:
> x.bbox && w.geometry AND st_within(x.geometry,w.geometry) and
>  count
>      0
> (1 row)
> Time: 1173.185 ms
> (same results with st_within(w.geometry,x.geometry):
> x.bbox && w.geometry AND st_within(w.geometry,x.geometry) and
>  count
>      0
> (1 row)
>   b) anything I can do to speed things up ? I have tried boosting work
> mem to 16 megs (from 1) and it made no apparent difference.
> I have a self contained test case that shows the same behavior -- the
> one large poly and all the candidates in another table. Apologies for
> the size; hopefully it's not been mangled in the transfers.
> Explain analyze of the sample (the sequential is sensible since there
> is only one row in the table):
> catest=# explain analyze select count(*) from wsc_candidates w,
> oli_req x WHERE w.geometry && x.bbox AND
> distance(w.geometry,x.oli_req_geom) > 0 AND x.oli_req_id = 114672;
> QUERY PLAN
>  Aggregate  (cost=20.28..20.29 rows=1 width=0) (actual
> time=77232.858..77232.859 rows=1 loops=1)
>    ->  Nested Loop  (cost=0.00..9.30 rows=4389 width=0) (actual
> time=6.389..77221.506 rows=12056 loops=1)
>          Join Filter: (distance(w.geometry, x.oli_req_geom) >
> 0::double precision)
>          ->  Seq Scan on oli_req x  (cost=0.00..1.01 rows=1
> width=40602) (actual time=0.007..0.009 rows=1 loops=1)
>                Filter: (oli_req_id = 114672)
>          ->  Index Scan using wsc_c_spatial_ndx on wsc_candidates w
> (cost=0.00..8.27 rows=1 width=109) (actual time=0.022..25.991
> rows=13168 loops=1)
>                Index Cond: (w.geometry && x.bbox)
>                Filter: (w.geometry && x.bbox)
>  Total runtime: 77232.901 ms
> (9 rows)
> Time: 77233.773 ms
> And for the real thing:
> catest=# explain analyze select count(*) from wtm_sub_cell w,
> order_line_item x WHERE w.geometry && x.bbox AND
> distance(w.geometry,x.geometry) = 0 AND x.id_as_int = 114672;
>        QUERY
> PLAN
>  Aggregate  (cost=141.83..141.84 rows=1 width=0) (actual
> time=77457.587..77457.588 rows=1 loops=1)
>    ->  Nested Loop  (cost=5.99..141.83 rows=1 width=0) (actual
> time=15.682..77456.541 rows=1112 loops=1)
>          Join Filter: (distance(w.geometry, x.geometry) = 0::double
> precision)
>          ->  Index Scan using oli_id_ndx on order_line_item x
> (cost=0.00..8.30 rows=1 width=383) (actual time=0.012..0.018 rows=1
> loops=1)
>                Index Cond: (id_as_int = 114672)
>          ->  Bitmap Heap Scan on wtm_sub_cell w  (cost=5.99..132.97
> rows=32 width=109) (actual time=2.988..21.796 rows=13168 loops=1)
>                ->  Bitmap Index Scan on wsc_geom_idx1
> (cost=0.00..5.98 rows=32 width=0) (actual time=2.828..2.828 rows=13168
> loops=1)
>  Total runtime: 77457.633 ms
> (10 rows)
> Time: 77458.458 ms
> The tables involved by size:
> catest=# select count(*) from wsc_candidates;
>  count
>  13168
> (1 row)
> Time: 2.586 ms
> catest=# select count(*) from oli_req;
>  count
>      1
> (1 row)
> Time: 0.193 ms
> catest=# select count(*) from wtm_sub_cell;
>   count
>  6399928
> (1 row)
> Time: 1776.508 ms
> catest=# select count(*) from order_line_item;
>  count
>  395921
> (1 row)
> Time: 176.083 ms
> Many thanks for your time and bandwidth!
> Greg Williamson
> Senior DBA
> GlobeXplorer LLC, a DigitalGlobe company
> Confidentiality Notice: This e-mail message, including any
> attachments, is for the sole use of the intended recipient(s) and may
> contain confidential and privileged information and must be protected
> in accordance with those provisions. Any unauthorized review, use,
> disclosure or distribution is prohibited. If you are not the intended
> recipient, please contact the sender by reply e-mail and destroy all
> copies of the original message.
> (My corporate masters made me say this.)
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
