[postgis-users] Retrieve Line coordinates from geometry.
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at gmail.com
Thu Jul 5 08:12:59 PDT 2007
Hi Broun.
If you want the start point of a linestring then you must use:
StartPoint(the_geom)
This function returns a POINT with the coordinates of the start point from
the_geom (for the end point you should use EndPoint(the_geom))
If you want to get the X and Y coordinates you should use the X() and Y()
functions with that points like:
X(StartPoint(the_geom)) and Y(StartPoint(the_geom))
Rodrigo.
On 7/5/07, Broun Uganda <tekuganda at hotmail.com> wrote:
> Dear all,
> Am trying to use the postgis reference to extract coordinates (x & y) for
> the starting and ending of a line from the_geom to enable me draw points
> at the starting and ending of that line. Please advise me which function i
> should use in my trigger function.
> I want to do something like this:
> UPDATE points SET the_geom = MakePoint(New.lines.the_geom(s),-1); where
> (s) refers to start of line geometry & (e) refers to end of line geometry
> UPDATE points SET the_geom = MakePoint(New.lines.the_geom(e),-1);
> Thanks
> Broun
> Make every IM count. Download Windows Live Messenger and join the i'm
> Initiative now. It's free. Make it count!<http://im.live.com/messenger/im/home/?source=TAGWL_June07>
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070705/5f87c039/attachment.html>
