[postgis-users] You've found a bug!
Obe, Regina
robe.dnd at cityofboston.gov
Tue Jul 17 12:42:23 PDT 2007
That's strange. I never thought shape files ever supported geometry
collections. Are you sure that last time you ran it maybe your collect
returned all multipoint or multipolygons and now with a newer dataset
your have a mixed back resulting in one or more records being a
geometrycollection?
What happens when you replace collect with geomunion?
thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of John
Cole
Sent: Tuesday, July 17, 2007 3:03 PM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] You've found a bug!
Running pgsql2shp with the following query on a tiger lkA table, I get a
notice that I've found a bug :-) This query worked with 8.1.
"select coalesce(fedirp || ' ', '') || fename || coalesce(' ' || fetype,
'') || coalesce(' ' || fedirs, '') as name, case when substring(fename,
'(Old)') is not null then null else substring(fename,
'(?:I[[:space:]]?-?|Highway|Hwy|County[[:space:]]Road|Co[[:space:]]Rd|Co
unty|State[[:space:]]Route|Parish|Parish[[:space:]]Road|S[[:space:]]R|C[
[:space:]]R|Sr|Co|Carretera|St[[:space:]]Rt|C Rd|Co
R|County[[:space:]]Route|Cr-?)+[[:space:]]?([[:digit:]]+)') end as
hwy_num, cfcc,
transform(simplify(segmentize(transform(collect(the_geom), 1000000), 1),
3), 4326) as the_geom from TGR01001 where substring(cfcc,
'(A[456789])+') is not null group by cfcc, hwy_num, fedirp, fename,
fetype, fedirs order by cfcc desc"
Preparing table for user query... Done.
Initializing... type 'GEOMETRYCOLLECTION' is not Supported at this time.
The DBF file will be created but not the shx or shp files.
You've found a bug! (pgsql2shp.c:2869)
Thanks,
John
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error please notify the
sender. This message contains confidential information and is intended
only for the individual named. If you are not the named addressee you
should not disseminate, distribute or copy this e-mail.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070717/7386b4b6/attachment.html>
