[postgis-users] Distance query not working after transfrom?
Alan Cunnane
alan_cunnane at yahoo.co.uk
Thu Jul 19 11:51:24 PDT 2007
Im having a problem with a distance query after I transformed a set of points to another SRID. I transformed from easting northing (SRID 27700) to longitude lattitude (SRID 4326). The problem that I am having is that when I do the same distance queries using both geom columns I get a completely different result? I know that the distance query using the first easting northing column is correct. Here is an example of the different returns I am getting:
SRID (27700):
SELECT a.stop_reference, b.stop_reference, distance(a.east_north, b.east_north) FROM bus_stops1 a, bus_stops1 b WHERE a.stop_reference = 6200206290 AND b.stop_reference = 6200244450;
stop_reference | stop_reference | distance
6200206290 | 6200244450 | 4320.88972319359
SRID (4326):
SELECT a.stop_reference, b.stop_reference, distance(a.googlemap, b.googlemap) FROM bus_stops1 a, bus_stops1 b WHERE a.stop_reference = 6200206290 AND b.stop_reference = 6200244450;
6200206290 | 6200244450 | 0.041147965100606
Here is the table I am selecting from:
Table "s0679212.bus_stops1"
Column | Type | Modifiers
stop_reference | character varying(12) | not null
easting | integer | not null
northing | integer | not null
full_location | character varying(50) |
gazetteer_code | character varying(1) |
point_type | character varying(1) |
nat_gazetteer | character varying(7) |
district_name | character varying(24) |
town_name | character varying(24) |
east_north | geometry | not null
lat | double precision |
lon | double precision |
googlemap | geometry |
Indexes:
"bus_stops1_pkey" PRIMARY KEY, btree (stop_reference)
"stops_distance1" gist (east_north)
Check constraints:
"enforce_dims_east_north" CHECK (ndims(east_north) = 2)
"enforce_dims_googlemap" CHECK (ndims(googlemap) = 2)
"enforce_geotype_east_north" CHECK (geometrytype(east_north) = 'POINT'::text OR east_north IS NULL)
"enforce_geotype_googlemap" CHECK (geometrytype(googlemap) = 'POINT'::text OR googlemap IS NULL)
"enforce_srid_east_north" CHECK (srid(east_north) = 27700)
"enforce_srid_googlemap" CHECK (srid(googlemap) = 4326)
I created the googlemap column using these commands:
SELECT AddGeometryColumn( 'bus_stops1', 'googlemap', 4326, 'POINT', 2 );
UPDATE bus_stops1 SET googlemap = transform(setsrid(makepoint(easting, northing),27700), 4326);
Can anyone suggest what on earth could be wrong?
___________________________________________________________
Yahoo! Mail is the world's favourite email. Don't settle for less, sign up for
your free account today http://uk.rd.yahoo.com/evt=44106/*http://uk.docs.yahoo.com/mail/winter07.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070719/72d3bc9e/attachment.html>
