[postgis-users] Distance query not working after transfrom?
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Thu Jul 19 11:55:07 PDT 2007
I think that this is an entirely correct result, as you are now getting
it in the new units, which are degrees, rather than meters.
r.b.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Alan
Cunnane
Sent: Thursday, July 19, 2007 2:51 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Distance query not working after transfrom?
Im having a problem with a distance query after I transformed a set of
points to another SRID. I transformed from easting northing (SRID 27700)
to longitude lattitude (SRID 4326).  The problem that I am having is
that when I do the same distance queries using both geom columns I get a
completely different result? I know that the distance query using the
first easting northing column is correct. Here is an example of the
different returns I am getting:
SRID (27700):
SELECT a.stop_reference, b.stop_reference, distance(a.east_north,
b.east_north) FROM bus_stops1 a, bus_stops1 b WHERE a.stop_reference =
6200206290 AND b.stop_reference = 6200244450;
stop_reference | stop_reference |     distance
 6200206290     | 6200244450     | 4320.88972319359
SRID (4326):
SELECT a.stop_reference, b.stop_reference, distance(a.googlemap,
b.googlemap) FROM bus_stops1 a, bus_stops1 b WHERE a.stop_reference =
 6200206290     | 6200244450     | 0.041147965100606
Here is the table I am selecting from:
            Table "s0679212.bus_stops1"
     Column     |         Type          | Modifiers
 stop_reference | character varying(12) | not null
 easting        | integer               | not null
 northing       | integer               | not null
 full_location  | character varying(50) |
 gazetteer_code | character varying(1)  |
 point_type     | character varying(1)  |
 nat_gazetteer  | character varying(7)  |
 district_name  | character varying(24) |
 town_name      | character varying(24) |
 east_north     | geometry              | not null
 lat            | double precision      |
 lon            | double precision      |
 googlemap      | geometry              |
Indexes:
    "bus_stops1_pkey" PRIMARY KEY, btree (stop_reference)
    "stops_distance1" gist (east_north)
Check constraints:
    "enforce_dims_east_north" CHECK (ndims(east_north) = 2)
    "enforce_dims_googlemap" CHECK (ndims(googlemap) = 2)
    "enforce_geotype_east_north" CHECK (geometrytype(east_north) =
'POINT'::text OR east_north IS NULL)
    "enforce_geotype_googlemap" CHECK (geometrytype(googlemap) =
'POINT'::text OR googlemap IS NULL)
    "enforce_srid_east_north" CHECK (srid(east_north) = 27700)
    "enforce_srid_googlemap" CHECK (srid(googlemap) = 4326)
I created the googlemap column using these commands:
SELECT AddGeometryColumn( 'bus_stops1', 'googlemap', 4326, 'POINT', 2 );
UPDATE bus_stops1 SET googlemap = transform(setsrid(makepoint(easting,
northing),27700), 4326);
Can anyone suggest what on earth could be wrong?
  _____
Yahoo! Mail is the world's favourite email. Don't settle for less, sign
up for your free account today
<http://uk.rd.yahoo.com/evt=44106/*http:/uk.docs.yahoo.com/mail/winter07
.html> .
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070719/130efc5e/attachment.html>
