[postgis-users] postgis with vb
Milo van der Linden mlinden at zeelandnet.nl
Fri Jul 20 10:46:37 PDT 2007
And especially here:
http://www.mapwindow.org/phorum/read.php?4,5679,5679#msg-5679
PostGIS support from this vb component is not completely supported, it
connects to postGIS, downloads the data as a shape file and opens it,
but if that would be enough for you, go ahead and try it.
Milo van der Linden,
http://www.3dsite.nl
> You mean that you need a Mapviewer component for VB?
> Try this: http://www.mapwindow.org/mapwingis.php
> Cristian Olguín Avila schreef:
>> ok.. but i don't explain very well..  i want to see the maps in vb
>> On 7/20/07, *Torsten Lange* <tlange at gwdg.de <mailto:tlange at gwdg.de>>
>> wrote:
>>     Hi Christian,
>>         Dim cn As New ADODB.Connection
>>         Dim rs1 As New ADODB.Recordset
>>         dim strSQL1 as string
>>         cn.Open "DSN=your_database;UID=xxx;PWD=yyy;"
>>         rs1.Open strSQL1, cn, adOpenStatic, adLockReadOnly, adCmdText
>>     works with VBA for Access.
>>     Torsten
>>     Cristian Olguín Avila schrieb:
>>     > hi...
>>     > i need help to connect and use my database postgresql with
>>     postgis...
>>     > with visual basic...
>>     > thanks
>>     > Cristian O.
>>     >_______________________________________________
>>     >postgis-users mailing list
>>     > postgis-users at postgis.refractions.net
>>     <mailto:postgis-users at postgis.refractions.net>
>>     >http://postgis.refractions.net/mailman/listinfo/postgis-users
>>     <http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> Cristian O.
> Milo van der Linden
> mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
> milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
> milo at 3dsite.nl <mailto:milo at 3dsite.nl>
> De informatie in dit bericht reflecteerd mijn persoonlijke mening en
> niet die van een bedrijf of instantie. Aan de informatie kunnen geen
> rechten worden ontleend. Indien dit bericht onderdeel is van een
> forum, mailing-list of community dan gelden automatisch de
> bijbehorende voorwaarden.
Milo van der Linden
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bijbehorende
voorwaarden.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070720/37df221d/attachment.html>
