[postgis-users] database wide unique ID
mlinden at zeelandnet.nl mlinden at zeelandnet.nl
Mon Jul 23 08:43:46 PDT 2007
That one crossed my mind, yes. But as far as I can see, the GUID is not a
standard object in postGres/postGIS. And since I am using INSERT INTO
(cols) SELECT cols_field FROM...
It seems a bit useless to use the php uniqid function because that would
mean that I would slow down my proces significantly;
- count rows; for each row generate GUID and insert into...
while now I have
- insert into for all rows at once.
> You might try using a GUID
> http://www.codeproject.com/netcf/PPCGuidGen.asp#The_GUID_Format
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Monday, July 23, 2007 7:30 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] database wide unique ID
> Hello list!
> Thanks to you all I have my first real import ready. Of course this is not
> enough for my employer ;-)
> For some extra functionality that is needed, we need a database wide
> unique ID. This is because our postGIS database will feed another (MSSQL)
> database with some sort of key index. In the MSSQL database, no difference
> is made between point,line and poly. Therefor my three tables (mypoint,
> myline and mypoly) need to have system wide ID's so I can return a
> relational table to MSSQL.
> Is there anyone that know how to generate a database wide unique ID?
> Thanks in advance!
> Milo van der Linden
> postgis-users mailing list
Milo van der Linden
<a href="http://somafm.com/"><img
src="http://somafm.com/linktous/450x25sfm1.gif" alt="SomaFM" border=0
width=450 height=25 ></a>
