[postgis-users] How to implement a GUID
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Tue Jul 24 06:43:13 PDT 2007
On Tue, 2007-07-24 at 15:27 +0200, Milo van der Linden wrote:
> Hello Mark,
> I am using your suggestion at this moment but the problem is as
> follows:
> I do an insert into the final_geom table which then uses a new id
> but;
> I need this id to do an insert into the final_attrib table!
> Basically what I want to do is:
> INSERT geom into table1 AND INSERT attrib1, attrib2, attrib3 into
> table2 FROM temp_table.
> The resulting table1 and table2 need to have exactly the same ID.
> I was first thinking about building an id in my temp_table and then do
> the 2 insert; But..my temp table is constantly created automatically
> by ogr2ogr, so I (seem to) have no influence on it's structure.
Ah OK - in that case you need to use currval() in the same transaction
as your original INSERT, e.g.
CREATE SEQUENCE seq1;
CREATE TABLE t1 AS (
        id int8 default nextval('seq1'),
        the_geom geometry
CREATE TABLE t2 AS (
        id int8,
        field varchar
BEGIN;
INSERT INTO t1 SELECT the_geom FROM geom_temp_table;
INSERT INTO t2 (id, field) SELECT currval('seq1'), myattribute FROM
geom_temp_table;
COMMIT;
And then check the results with:
	SELECT id FROM t1;
	SELECT id FROM t2;
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
