[postgis-users] Warning GEOS is NOT enabled
Marc Desharnais
marc.desharnais at ec.gc.ca
Tue Jul 24 12:50:04 PDT 2007
Hi Mark,
I did a make install. Maybe someone can tell me if I missed something to
make GEOS work properly with Postgis.
But my Postgresql is not installed in a default directory. So maybe
there is a problem with that.
What library should I check to be sure that it's well installed?
Marc
Mark Cave-Ayland wrote:
> On Fri, 2007-07-20 at 17:56 +0000, Marc Desharnais wrote:
>> Hi all,
>> I recompiled postgis from scratch lately with support for GEOS, which
>> I compiled too. I confirm that GEOS' bin directory is in my path.
>> When I start Geoserver I keep getting this warning message.
>> "[main] WARN org.geotools.data.postgis - GEOS is NOT enabled. This
>> will result in limited functionality and performance."
>> Which made me doubt about my installation.
>> I want GEOS working on that server. Why is it saying that if I
>> compiled PostGIS against GEOS?
>> Below is the result of my config command. I did a "make clean" then I
>> recompiled PostGIS after that. Then relaunched PostGIS and Geoserver.
>> And I still got this message.
>> Then I executed this command in PostGIS to check
>> #select postgis_version();
>> postgis_version
>> 1.2 USE_GEOS=0 USE_PROJ=0 USE_STATS=1
>> (1 row)
>> Which confirm that it's not working, but why?
> Hi Marc,
> How exactly did you recompile PostGIS? Did you remember to do a "make
> install" rather than just "make" to copy the updated version of the
> PostGIS library into that of your PostgreSQL installation?
> Kind regards,
> Mark.
