[postgis-users] ERROR: could not load library ... liblwgeom.so.1.2
Uwe Seher uwe.seher at googlemail.com
Wed Jul 25 00:27:36 PDT 2007
Am 24.07.2007, 18:45 Uhr, schrieb Gilles Bassière
<gilles.bassiere at makina-corpus.com>:
> Hi list
> I'm in trouble with a fresh install of postGIS 1.2.1 with postgreSQL
> 8.2.4
> After database creation (and plpgsql language creation), I tried to load
> postgis function by issuing the command:
>     psql -d netherlands -f /home/gba/apps/share/lwpostgis.sql
> and I got the following error:
>     psql:/home/gba/apps/share/lwpostgis.sql:43: ERROR:  could not load
> library "/home/gba/apps/lib/liblwgeom.so.1.2": libgeos_c.so.1: cannot
> open shared object file: No such file or directory
> It seems to be a simple misconfiguration but...
> 1) libgeos_c.so.1 exists, it's located in /home/gba/apps/lib, as
> liblwgeom.so.1.2.
> 2) /home/gba/apps/lib is in LD_LIBRARY_PATH and in a conf file in
> /etc/ld.so.conf.d
> 3) I did ldconfig as root
> 4) Finally, ldd /home/gba/apps/lib/liblwgeom.so.1.2
> /home/gba/apps/lib/libgeos_c.so.1 ouputs the following:
> /home/gba/apps/lib/liblwgeom.so.1.2:
>         linux-gate.so.1 =>  (0xffffe000)
>         libgeos_c.so.1 => /home/gba/apps/lib/libgeos_c.so.1 (0xb7f08000)
>         libproj.so.0 => /home/gba/apps/lib/libproj.so.0 (0xb7ed5000)
>         libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7d87000)
>         libgeos.so.2 => /home/gba/apps/lib/libgeos.so.2 (0xb7c83000)
>         libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7b99000)
>         libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7b72000)
>         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7b66000)
>         /lib/ld-linux.so.2 (0x80000000)
> /home/gba/apps/lib/libgeos_c.so.1:
>         libgeos.so.2 => /home/gba/apps/lib/libgeos.so.2 (0xb7e21000)
>         libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7d2b000)
>         libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7d03000)
>         libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7bc2000)
>         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7bb6000)
> I read several posts on this list related to library problems and tried
> the proposed solutions but I still can't get rid of that error...
> Is there any known bug about Geos and PostGis, do I use the right
> versions ?
> By the way, here is some additional information about my config
> - Ubuntu 7.0.4 feisty
> - postgreSQL 8.2.4 installed through apt-get
> - geos 2.2.3 compiled from source
> - proj 4.5.0 compiled from source
> I'm stuck... Does anybody can help ?
Hi!
I had the same promlem, some time ago. It disappeard when i was starting
the sql-command inside the sourcetree of postgis. Another solution was to
change the path variable in the sql-statement with the absolute path to
the lib. No brilliant solution, but it works... ;)
If you have a fresh geos-installation, an ldconfig -v (?) in maybe usefull.
Another thing: you have to ensure, that the postgres-user can read the
lib, so you have zu check the rw-settings in your /home-dir.
Bye Uwe
_____________________________________
ingenieurbüro kauppert
nebeniusstr. 34
d-76137 karlsruhe
fon   +49 721 3548969-3
fax   +49 721 3548969-5
email uwe.seher at ib-kauppert.de
web   www.ib-kauppert.de
