[postgis-users] Warning GEOS is NOT enabled
Tim Bowden tim.bowden at westnet.com.au
Wed Jul 25 02:33:00 PDT 2007
On Tue, 2007-07-24 at 23:34 +0100, Mark Cave-Ayland wrote:
> On Tue, 2007-07-24 at 19:50 +0000, Marc Desharnais wrote:
> Finally, for the PostgreSQL server to find these libraries, you'll need
> to make sure that the LD_LIBRARY_PATH environment variable is set for
> the user under which the PostgreSQL server runs to find the directories
> containing all the .so files - you'll need something like this:
> LD_LIBRARY_PATH=/data/ulysse/postgis_geos/GEOS/lib:/data/ulysse/postgis_geos/PROJ4/lib
> HTH,
> Mark.
Or put the lib location in /etc/ld.so.conf and run ldconfig
Tim Bowden
