[postgis-users] Performace problems with 250.000.000 points
Boehm, Andreas boehm at rif.fuedo.de
Wed Jul 25 11:42:34 PDT 2007
Hi Mark, Patricio, Brent and Paul (and all the others of course)
thanks for your answers.
--- Mark wrote:
> SELECT * FROM trees WHERE geom && (SELECT geom FROM
> land_parcel WHERE lp_id = 123456);
There's quite no difference. Please refer to the explain analyses at the
end of this mail.
--- Patricio wrote:
> Aplicate case box3d
Should I realy add bounding boxes for points? Could it be faster testing
the box than testing the point? Or does it just blow up the trees table?
--- Brent wrote:
> speed up by tiling your trees into (for example) 10000 "boxes"
I have not implemented it yet. But isn't it the way the geometry index
is for? The index should also reduce the trees to be tested.
--- Paul wrote:
> use
> shared_buffers = 1024MB
> effective_cache_size = 1024MB
> random_page_cost = 3
It sounds silly, but these parameters even slow it down. With this
configuration Posgres uses much more memory. Starting your query you can
see the mem usage raising. But at the end the results aren't faster than
the original settings.
I changed the testing a bit. Now I read 100 land_parcels uniformly
distributed over the database. For each land_parcel I additionally read
the next 10 land_parcels. These neighbours return very quickly, off
course.
Thanks
Andreas
P.S. Here are the explain analyses:
EXPLAIN ANALYZE
SELECT * FROM land_parcel WHERE lp_id = 123456;
Index Scan using land_parcel_pkey on land_parcel  (cost=0.00..9.25
rows=1 width=342) (actual time=0.016..0.017 rows=1 loops=1)
  Index Cond: (lp_id = 123456)
Total runtime: 0.045 ms
EXPLAIN ANALYSE
SELECT x(geom), y(geom)
FROM trees
WHERE geom && (SELECT geom FROM land_parcel WHERE lp_id = 123456);
Bitmap Heap Scan on trees  (cost=108.73..5063.01 rows=1250 width=21)
(actual time=716.319..717.002 rows=18 loops=1)
  Filter: (geom && $0)
  InitPlan
    ->  Index Scan using land_parcel_pkey on land_parcel
(cost=0.00..9.25 rows=1 width=317) (actual time=0.096..0.098 rows=1
loops=1)
  ->  Bitmap Index Scan on trees_index  (cost=0.00..99.16 rows=1250
width=0) (actual time=716.176..716.176 rows=18 loops=1)
        Index Cond: (geom && $0)
Total runtime: 717.082 ms
EXPLAIN ANALYZE
select x(t.geom), y(t.geom)
from land_parcel as l, trees as t
where (l.lp_id = 123456)
and (l.geom && t.geom) and Contains(l.geom, t.geom)
Nested Loop  (cost=99.47..5072.48 rows=19 width=21) (actual
time=722.931..723.639 rows=16 loops=1)
  Join Filter: contains(l.geom, t.geom)
  ->  Index Scan using land_parcel_pkey on land_parcel l
(cost=0.00..9.25 rows=1 width=317) (actual time=0.205..0.208 rows=1
loops=1)
  ->  Bitmap Heap Scan on trees t  (cost=99.47..5044.38 rows=1250
width=21) (actual time=722.541..723.197 rows=18 loops=1)
        Filter: (l.geom && t.geom)
rows=1250 width=0) (actual time=722.417..722.417 rows=18 loops=1)
              Index Cond: (l.geom && t.geom)
Total runtime: 723.759 ms
