AW: [postgis-users] PostGIS and Hibernate
Dave Potts
dave.potts at pinan.co.uk
Fri Jul 27 00:43:11 PDT 2007
Thorsten Kraus wrote:
Can't help you with one, but with 2, it works for ME!
create a context.xml file in your META-INT like
<!-- Connection details for Hibernate
NOTE This isntace is readonly
<Context>
<Resource name="jdbc/castleDB" auth="Container"
type="javax.sql.DataSource" username="data_user" password=""
driverClassName="org.postgresql.Driver"
url="jdbc:postgresql://127.0.0.1/castle"
maxActive="8"
maxIdle="4" />
</Context>
Put the hibernate config file in webapps/mma/WEB-INF/classes
<hibernate-configuration>
<!-- a SessionFactory instance listed as /jndi/name -->
<session-factory>
<!-- properties -->
<property
name="connection.datasource">java:/comp/env/jdbc/castleDB</property>
<property
name="dialect">org.hibernate.dialect.PostgreSQLDialect</property>
<property name="show_sql">true</property>
<property name="use_outer_join">true</property>
<property
name="hibernate.cache.provider_class">org.hibernate.cache.NoCacheProvider</property>
<property name="generate_statistics">true</property>
<property name="cache.use_query_cache">false</property>
<property name="cache.use_minimal_puts">false</property>
<property
name="current_session_context_class">thread</property>
<property name="max_fetch_depth">3</property>
<property name="c3p0.min_size">3</property>
<property name="c3p0.max_size">5</property>
<property name="c3p0.timeout">1800</property>
<!-- mapping files -->
<mapping resource="uk/co/pinan/mma/dto/CountyDTO.hbm.xml"/>
<mapping resource="uk/co/pinan/mma/dto/CastleDTO.hbm.xml"/>
<mapping
resource="uk/co/pinan/mma/dto/OwnerMapDTO.hbm.xml"/>
<mapping
resource="uk/co/pinan/mma/dto/PlaceNameDTO.hbm.xml"/>
<mapping resource="uk/co/pinan/mma/dto/OwnerDTO.hbm.xml"/>
<mapping resource="uk/co/pinan/mma/dto/HundredDTO.hbm.xml"/>
<mapping resource="uk/co/pinan/mma/dto/PlaceDTO.hbm.xml"/>
</session-factory>
</hibernate-configuration>
And use something like to map your files
<!DOCTYPE hibernate-mapping PUBLIC
"-//Hibernate/Hibernate Mapping DTD 3.0//EN"
"http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping
<class
name="uk.co.pinan.mma.dto.OwnerDTO"
table="owner_table"
<id
name="ownerId"
column="owner_id"
type="int"
<generator class="native">
To add non XDoclet generator parameters, create a file
named
hibernate-generator-params-OwnerDTO.xml
containing the additional parameters and place it in
your merge dir.
</generator>
</id>
<property
name="ownerName"
type="text"
update="true"
insert="true"
column="owner_name"
<property
name="churchman"
type="boolean"
update="true"
insert="true"
column="churchman"
To add non XDoclet property mappings, create a file named
hibernate-properties-OwnerDTO.xml
containing the additional properties and place it in your
merge dir.
</class>
</hibernate-mapping>
> Hi Andy,
> thanks for this useful information. I read the ejb3spatial.pdf and
> have some further questions on this topic :)
> 1. You mentioned that Norman Barker has created a user type for
> Hibernate. Is this user type an official component of the Hibernate
> framework or is it an addition where no support from the Hibernate
> team is guaranteed?
> 2. The tutorial in the pdf uses JBoss as application server. In my
> project I use Tomcat. So Tomcat is not a full application server, I
> think it is not possible to use Hibernate for PostGIS access in my
> project without changing the application server. Is this right?
> Thanks,
> Thorsten
> -----Ursprüngliche Nachricht-----
> *Von:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]*Im Auftrag
> von *Andy Dale
> *Gesendet:* Freitag, 27. Juli 2007 09:10
> *An:* PostGIS Users Discussion
> *Betreff:* Re: [postgis-users] PostGIS and Hibernate
> Hi Thorsten,
> A person called Norman Barker has created a user type for
> Hibernate, this can be accessed here
> http://svn.refractions.net/postgis/trunk/java/ejb3/
> <http://svn.refractions.net/postgis/trunk/java/ejb3/>also read the
> ejb3spatial.pdf located here as it gives a example of how to use it.
> Cheers,
> Andy
> On 27/07/07, *Thorsten Kraus* < Thorsten.Kraus at ptv.de
> <mailto:Thorsten.Kraus at ptv.de>> wrote:
> Hi all,
> currently I am working for a project which uses PostGIS to
> store spatial objects in the backend of an web application
> (Tomcat is used as servlet container). Some time ago I
> searched the web for Hibernate support for PostGIS database
> and its geographical objects, but found nothing suitable. So I
> use Hibernate for non geographical attribute data and wrote
> some JDBC code for accessing the geographical objects in
> PostGIS. This hybrid structure of Hibernate and JDBC works
> fine, but it would even be nicer and more flexible if there
> was a possibility to handle all the database stuff with
> Hibernate.
> Can you tell me if there is Hibernate support for PostGIS
> meanwhile? If yes, a piece of code or a link to a tutorial
> would be pleasant.
> Kind regards,
> Thorsten
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070727/8483179a/attachment.vcf>
