[postgis-users] use of the affine() function
Dylan Beaudette
dylan.beaudette at gmail.com
Sat Jun 2 16:30:43 PDT 2007
On Tuesday 29 May 2007 12:41, Dylan Beaudette wrote:
> > In order to turn a set of [src, dest] coordinate pairs into an affine
> > transformation, you have to solve a system of linear equations. The
> > solution is the entries in the require affine transformation matrix. In
> > order to fully determine an affine transformation you need 3 control
> > points and their images under the transformation.
Ok, here is a quick how-to:
http://casoilresource.lawr.ucdavis.edu/drupal/node/433
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
