[postgis-users] Installation with Proj
Andy Dale andy.dale at gmail.com
Mon Jun 4 02:54:59 PDT 2007
After installing proj, the contents under /usr/local/lib are
-rw-r--r-- 1     root root 1300710 Jun 4 12:05 libproj.a
-rwxr-xr-x 1   root root 796 Jun 4 12:05 libproj.la
lrwxrwxrwx 1 root root 16 Jun 4 12:05 libproj.so -> libproj.so.0.5.2
lrwxrwxrwx 1 root root 16 Jun 4 12:05 libproj.so.0 -> libproj.so.0.5.2
-rwxr-xr-x 1   root root 758060 Jun 4 12:05 libproj.so.0.5.2
Postgis recompiled fine after the installation of proj, it even auto found
the proj on the system.  The problem comes when i try and run the sql script
to upgrade postgis
Cheers,
Andy
On 04/06/07, jrom <jerome.gasperi at gmail.com> wrote:
> Hi Andy,
> After ./configure did you recompile postgis without any problem ?
> If the compilation ran well then you should check under /usr/local/lib
> if you have libproj.so.0 file that should be a link to the current
> libproj.
> For example a typical proj 5 installation you should have something
> like this under /usr/local/lib :
> lrwxrwxrwx 1 gass gass      16 2005-09-13 14:47 libproj.so ->
> libproj.so.0.5.0
> lrwxrwxrwx 1 gass gass      16 2005-09-13 14:47 libproj.so.0 ->
> libproj.so.0.5.0
> -rwxr-xr-x 1 gass gass  657462 2005-09-13 14:47 libproj.so.0.5.0
> As you can see libproj.so.0 is a dynamic link to libproj.so.0.5.0.
> If this link is not present you can create it
> Hope this help
> On 6/4/07, Andy Dale <andy.dale at gmail.com> wrote:
> > Hi,
> > I managed to install and use Postgis without any problems,
> > but later found out that i could not do any
> > reprojections without the proj library.
> > I downloaded and installed the proj library.  I then
> > attempted to re-install Postgis with proj
> > support like so:
> > ./configure --with-proj=yes (without specifying this flag it still find
> the
> > proj library) It produces the following output:
> > SUMMARY
> >  HOST_OS: linux-gnu
> > PGSQL: /usr/bin/pg_config
> > PROJ: prefix=/usr/local libdir=/usr/local/lib
> > ICONV: 1
> > PORTNAME: linux
> >  PREFIX: /usr
> > EPREFIX: ${prefix}
> >  DOC: /usr/share/doc/postgresql/contrib
> >  DATA: ${datarootdir}
> >  MAN: ${datarootdir}/man
> >  BIN: /usr/bin
> >  EXT: /usr/lib/pgsql (\$$libdir)
> > Now when i try to run either the lwpostgis_upgrade.sql or lwpostgis.sql
> > (creates histogram2d then fails) i get the following error
> > ERROR: could not load library
> > "/usr/lib/pgsql/liblwgeom.so.1.2": libproj.so.0: cannot
> > open shared object file: No such file or directory
> > Can anyone tell me where i have gone wrong in the installation ??
> > Thanks in advance,
> > Andy
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> J.
> http://geogurus.org/jrom
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070604/93dc8d70/attachment.html>
