[postgis-users] Installation with Proj
Andy Dale
andy.dale at gmail.com
Mon Jun 4 03:26:41 PDT 2007
Unfortunately after running a /sbin/ldconfig i am still left with the same
error. When installing postgis to a "virgin" db, it manages to create the
histogram2d datatype like so:
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
and then gets the same error
Cheers,
Andy
On 04/06/07, Rob Agar <robagar at westnet.com.au> wrote:
> I think I had this same problem - if it was the same one, running
> ldconfig to rebuild the shared object cache fixed it.
> ht (might) h
> Rob
> Andy Dale wrote:
> > After installing proj, the contents under /usr/local/lib are
> > -rw-r--r-- 1 root root 1300710 Jun 4 12:05 libproj.a
> > -rwxr-xr-x 1 root root 796 Jun 4 12:05 libproj.la <http://libproj.la>
> > lrwxrwxrwx 1 root root 16 Jun 4 12:05 libproj.so -> libproj.so.0.5.2
> > lrwxrwxrwx 1 root root 16 Jun 4 12:05 libproj.so.0 -> libproj.so.0.5.2
> > -rwxr-xr-x 1 root root 758060 Jun 4 12:05 libproj.so.0.5.2
> > Postgis recompiled fine after the installation of proj, it even auto
> > found the proj on the system. The problem comes when i try and run the
> > sql script to upgrade postgis
> > Cheers,
> > Andy
> > On 04/06/07, *jrom* <jerome.gasperi at gmail.com
> > <mailto:jerome.gasperi at gmail.com>> wrote:
> > Hi Andy,
> > After ./configure did you recompile postgis without any problem ?
> > If the compilation ran well then you should check under
> /usr/local/lib
> > if you have libproj.so.0 file that should be a link to the current
> > libproj.
> > For example a typical proj 5 installation you should have something
> > like this under /usr/local/lib :
> > lrwxrwxrwx 1 gass gass 16 2005-09-13 14:47 libproj.so ->
> > libproj.so.0.5.0
> > lrwxrwxrwx 1 gass gass 16 2005-09-13 14:47 libproj.so.0 ->
> > libproj.so.0.5.0
> > -rwxr-xr-x 1 gass gass 657462 2005-09-13 14:47 libproj.so.0.5.0
> > As you can see libproj.so.0 is a dynamic link to libproj.so.0.5.0.
> > If this link is not present you can create it
> > Hope this help
> > On 6/4/07, Andy Dale <andy.dale at gmail.com
> > <mailto:andy.dale at gmail.com>> wrote:
> > > Hi,
> > > I managed to install and use Postgis without any problems,
> > > but later found out that i could not do any
> > > reprojections without the proj library.
> > > I downloaded and installed the proj library. I then
> > > attempted to re-install Postgis with proj
> > > support like so:
> > > ./configure --with-proj=yes (without specifying this flag it
> > still find the
> > > proj library) It produces the following output:
> > > SUMMARY
> > > HOST_OS: linux-gnu
> > > PGSQL: /usr/bin/pg_config
> > > PROJ: prefix=/usr/local libdir=/usr/local/lib
> > > ICONV: 1
> > > PORTNAME: linux
> > > PREFIX: /usr
> > > EPREFIX: ${prefix}
> > > DOC: /usr/share/doc/postgresql/contrib
> > > DATA: ${datarootdir}
> > > MAN: ${datarootdir}/man
> > > BIN: /usr/bin
> > > EXT: /usr/lib/pgsql (\$$libdir)
> > > Now when i try to run either the lwpostgis_upgrade.sql or
> > lwpostgis.sql
> > > (creates histogram2d then fails) i get the following error
> > > ERROR: could not load library
> > > "/usr/lib/pgsql/liblwgeom.so.1.2": libproj.so.0: cannot
> > > open shared object file: No such file or directory
> > > Can anyone tell me where i have gone wrong in the installation ??
> > > Thanks in advance,
> > > Andy
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > <mailto:postgis-users at postgis.refractions.net>
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > J.
> > http://geogurus.org/jrom
> > <http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070604/7c9ce21a/attachment.html>
